Items with no label
3338 Discussions
synchronization, fisheye external trigger
SXiao8
I am using Realsense ZR300 on windows 10 by librealsense this days. When enable fisheye_external_trigger, the fisheye frame rate is forcedly turned to be 30HZ. Why? I need capture fisheye frame at 60HZ and enable fisheye_external_trigger at the same time, for synchronization.
Hello Shon,
Thanks for reaching out!
First of all, I would like to point out that, as it can be seen in https://www.intel.com/content/www/us/en/support/emerging-technologies/intel-realsense-technology/000023520.html, the ZR300 is not validated to work in Windows 10.
However, I would like to point out this document: https://communities.intel.com/docs/DOC-111978 https://communities.intel.com/docs/DOC-111978. It is about the known issues of the Intel® Euclid™ Development Kit. As you may know, Euclid also uses a ZR300. In the list of known issues you'll find that there are issues with the fisheye camera. Among them, you'll find the following: "...Fisheye FPS currently is 30 fps, cannot be changed..."
So, unfortunately, this is a limitation of librealsense and the fisheye camera.
I hope this information helps you,
Pedro M.
Hello Shon,
Pedro M.
SXiao8
Your reply help me a lot. Thank you very much.
Hi Shon,
I'm really glad to be of help!
If you ever have any other questions or doubts, please don't hesitate to come back to the community.
Pedro M.
