Items with no label
3338 Discussions
t265 possible to see tracked features?
HDiet
Is it possible to see the tracked features in an image of the enviroment the t265 uses for the slam algorithm?
best regards
MartyG
The RealSense Viewer software provides 2D visualization of IMU and Tracking data. 3D visualization is available for Pose samples.
Another way to visualize tracking information would be through ​ROS.
https://youtu.be/GhHvuAoFC6I
HDiet
thx. Am I right, that the cameras track special information in a room, for example the edge of a chair or something. And this is what I want to see in an image. Is that possible? Is it also possible to change the (min/max)number of features the cameras should track or is it fixed somewhere deep in the hardware/software?
MartyG
The T265 can recognize visual cues, patterns and landmarks in the environment (such as patterns on walls and floors) and use them for navigation. An Intel spokesperson said: "“You can use things like patterns on the wall or on the floor or on the ceiling to infer your location, which would not be observable with a depth camera or lidar”. It helps robots to avoid getting lost, something known as the "kidnapped robot" problem.
I carefully researched your question about the min-max number of trackable features but could not find such a feature. I believe the  163 ±5° combined FOV of the fisheye lenses is designed to capture as many landmarks as possible.
