Items with no label
3338 Discussions
use depth_image_proc/point_cloud_xyz with rosbag file
MEppl
Hey,
I'm recording the topics "/camera/depth/camera_info" and "/camera/depth/image_rect_raw" from D435 to a bag file. While playing the bag file I would like to start a node that converts the depth image to a pointcloud2 message. I think therefore I have to use "depth_image_proc/point_cloud_xyz".
This is how you do it in your launch files:
args="load depth_image_proc/point_cloud_xyz $(arg manager) $(arg bond)" respawn="$(arg respawn)">
But in your cases always the realsense node is running. I think that's the reason why you can use nodelets with pointers. In my case a nodelet is not working. Is this right?
How can I generate a poincloud2 message from a bag file ? Or do I have to record other topics from "realsense2_camera_manager" to simulate a running realsense node ?
Thanks for your help!
MartyG
I'm not sure if this is what you needed, but I got results that seemed useful by searching Google for the term 'depth_image_proc example'. Here's a couple of examples from a search:
https://gist.github.com/bhaskara/2400165 Example ROS launch file that uses depth_image_proc to convert an RGB-depth image pair into a point cloud · GitHub
https://answers.ros.org/question/216748/how-to-use-depth_image_procpoint_cloud_xyzrgb-nodelet-with-rosbag/ https://answers.ros.org/question/216748/how-to-use-depth_image_procpoint_cloud_xyzrgb-nodelet-with-rosbag/
MartyG
MEppl
I've also seen these examples, but was confused because they all use OpenNI, which is not supported by realsense.
After taking a closer look I saw that in my case I don't need the OpenNI camera drivers. It works, thanks !
MartyG
I'm very glad it worked for you - thanks for letting us know!
