Items with no label
3338 Discussions
zr300 ubuntu 16.04 server edition undefined symbol: libusb_get_parent
MDiou
Dear Support,
System (Server edition - [cat lsb_release]):
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04 LTS"
PC: https://ark.intel.com/products/83257 Intel® NUC Kit NUC5i3RYH Product Specifications
While following this guide https://software.intel.com/sites/products/realsense/intro/getting_started.html Introduction to Intel® RealSense™ SDK for Linux: Getting Started I have encountered the following error when running:
/usr/bin/rs_or_tutorial_1_gui or cpp-capture
errors:
/usr/bin/rs_or_tutorial_1_gui: symbol lookup error: /usr/lib/x86_64-linux-gnu/librealsense.so.1: undefined symbol: libusb_get_parent
cpp-capture: symbol lookup error: /usr/lib/x86_64-linux-gnu/librealsense.so.1: undefined symbol: libusb_get_parent
These are the libusb packages on my system (dpkg --get-selections | grep libusb):
libusb++-0.1-4v5:amd64 install
libusb++-dev install
libusb-0.1-4:amd64 install
libusb-1.0-0:amd64 install
libusb-1.0-0-dbg:amd64 install
libusb-1.0-0-dev:amd64 install
libusb-1.0-doc install
libusb-dev install
I have tried following this forum post to solve the problem (https://stackoverflow.com/questions/28835794/undefined-reference-to-libusb-get-parent-compiling-freenect makefile - Undefined reference to libusb_get_parent() - compiling freenect - Stack Overflow )
The only difference is that instead of using the following command
sudo ln -s /usr/lib/libusb-1.0.so /usr/lib/arm-linux-gnueabihf/libusb-1.0.so
I used the following command
sudo ln -s /usr/lib/libusb-1.0.so /usr/lib/x86_64-linux-gnu/libusb-1.0.so
as /usr/lib/x86_64-linux-gnu/librealsense.so.1 is in the directory /usr/lib/x86_64-linux-gnu/ not /usr/lib/arm-linux-gnueabihf/
But upgrading to version 1.0.21 of libusb-1.0-0-dev does not solve the problem.
I have version 1.0.20-1 of libusb-1.0-0-dev and libsusb-1.0.0 installed on my system (dpkg -s libusb-1.0-0 && dpkg -s libusb-1.0-0-dev):
Package: libusb-1.0-0-dev
Status: install ok installed
Priority: optional
Section: libdevel
Installed-Size: 264
Maintainer: Ubuntu Developers <</span>mailto:ubuntu-devel-discuss@lists.ubuntu.com ubuntu-devel-discuss@lists.ubuntu.com>
Architecture: amd64
Multi-Arch: same
Source: libusb-1.0
Version: 2:1.0.20-1
Depends: libusb-1.0-0 (= 2:1.0.20-1)
Recommends: libusb-1.0-doc
Priority: optional
Section: libs
Installed-Size: 122
Architecture: amd64
Multi-Arch: same
Source: libusb-1.0
Version: 2:1.0.20-1
Depends: libc6 (>= 2.17), libudev1 (>= 183)
Would you kindly be able to provide me with assistance ?
MartyG
As you are using a Server version of Ubuntu, my first question would be if you have set Librealsense up on a Virtual Machine. Librealsense's documentation says, "Due to the USB 3.0 translation layer between native hardware and virtual machine, the librealsense team does not recommend or support installation in a VM."
MDiou
Hello MartyG, thank you for the prompt reply,
No librealsense is not installed on a Virtual machine.
MartyG
Some other people who had the undefined symbol: libusb_get_parent error found that they fixed it by building libusb from the latest version of it instead of an old version like libusb 1.0. The latest version is 1.0.21
http://libusb.info/ libusb
MartyG
I apologize - I have not dealt with this error before, so I am learning about it as I research.
I wonder if there is an issue with the format of your command (swapping Arm for x86). Someone else phrased the command like this:
sudo ln -sf /lib/x86_64-linux-gnu/libusb-1.0.so.0 /usr/local/lib/libusb-1.0.so.0
MDiou
Not at all thank you for taking the time to answer and help out.
The problem is now fixed.
Your previous reply sent me in the right direction, the libraries that were being used where that of /usr/local/lib/libusb-1.0.so.
And not of
by replacing the
/usr/local/lib/libusb-1.0.so.0.1.0
with the libusb-1.0.21
/usr/lib/libusb-1.0.so.0
/usr/lib/libusb-1.0.so.0.1.0
The error disappeared
MartyG
Awesome news! Good luck with the rest of your project, and please come back to the forum any time that you have new questions.
