Add audio effect with mp3(audio/mpeg)
JIHOON_O_
I've been trying to add audio effect with mp3(audio/mpeg) but I can't make it.
It crashes with BufferOverflowException.
The log message is
 java.nio.BufferOverflowException
            at java.nio.ByteBuffer.put(ByteBuffer.java:787)
            at com.intel.inde.mp.domain.Frame.copyDataFrom(Frame.java:91)
            at com.intel.inde.mp.domain.pipeline.CopyDataCommandHandler.handle(CopyDataCommandHandler.java:33)
            at com.intel.inde.mp.domain.CommandProcessor.process(CommandProcessor.java:114)
            at com.intel.inde.mp.domain.CommandProcessor.process(CommandProcessor.java:86)
            at com.intel.inde.mp.domain.CommandProcessor.processCommandPairs(CommandProcessor.java:78)
            at com.intel.inde.mp.domain.CommandProcessor.process(CommandProcessor.java:50)
            at com.intel.inde.mp.MediaComposer$1.run(MediaComposer.java:344)
            at java.lang.Thread.run(Thread.java:818)
What I've tried things to solve this problem are
- change the value of audioFormat.setKeyMaxInputSize(48 * 1024)
- change targetSampleRate value
- change the value of byteBuffer.limit(mAudioDecoderOutputBufferInfo.size); and decoderOutputBuffer.limit(mAudioDecoderOutputBufferInfo.size);
but these things didn't help.
so, I printed log with buffer's value.
D/EqualRateAudioReader﹕ EqualRateAudioReader read start
D/EqualRateAudioReader﹕ decoderInputBufferIndex : 0
D/EqualRateAudioReader﹕ decoderInputBuffer.capacity() 524288, decoderInputBuffer.limit() 524288
D/EqualRateAudioReader﹕ SampleData size : 417
D/EqualRateAudioReader﹕ Presentation Time : 0
D/EqualRateAudioReader﹕ mAudioExtractor.getSampleFlags() : 1
I/ACodec﹕ >>> getPortFormat 16, OMX.SEC.mp3.dec
D/EqualRateAudioReader﹕ decoderOutputBufferIndex MediaCodec.INFO_OUTPUT_FORMAT_CHANGED
D/EqualRateAudioReader﹕ decoderInputBufferIndex : 1
D/EqualRateAudioReader﹕ SampleData size : 418
D/EqualRateAudioReader﹕ Presentation Time : 26122
D/EqualRateAudioReader﹕ decoderOutputBufferIndex : 0
D/EqualRateAudioReader﹕ mAudioDecoderOutputBufferInfo.offset : 0
D/EqualRateAudioReader﹕ mAudioDecoderOutputBufferInfo.size : 2492
D/EqualRateAudioReader﹕ byteBuffer.capacity() 1048576
D/EqualRateAudioReader﹕ byteBuffer.limit() 2492
D/EqualRateAudioReader﹕ decoderOutputBuffer.capacity() 27648
D/EqualRateAudioReader﹕ decoderOutputBuffer.limit() 2492
D/SubstituteAudioEffect﹕ timeProgress 0
D/SubstituteAudioEffect﹕ input.limit() 24576, input.capacity() 24576, byteBuffer.limit() 2492, byteBuffer.capacity() 1048576
I/AMP﹕ New frame allocated for buffer 0
I/AMP﹕ New frame allocated for buffer 12
D/EqualRateAudioReader﹕ decoderInputBufferIndex : 2
D/EqualRateAudioReader﹕ Presentation Time : 52244
D/EqualRateAudioReader﹕ decoderOutputBufferIndex : 1
D/EqualRateAudioReader﹕ mAudioDecoderOutputBufferInfo.size : 4608
D/EqualRateAudioReader﹕ byteBuffer.limit() 4608
D/EqualRateAudioReader﹕ decoderOutputBuffer.limit() 4608
D/SubstituteAudioEffect﹕ timeProgress 23219
D/SubstituteAudioEffect﹕ input.limit() 24576, input.capacity() 24576, byteBuffer.limit() 4608, byteBuffer.capacity() 1048576
I/AMP﹕ New frame allocated for buffer 11
I/MPEG4Writer﹕ setStartTimestampUs: 0
I/MPEG4Writer﹕ Earliest track starting time: 0
I/AMP﹕ New frame allocated for buffer 2
D/EqualRateAudioReader﹕ decoderInputBufferIndex : 3
D/EqualRateAudioReader﹕ Presentation Time : 78367
D/EqualRateAudioReader﹕ decoderOutputBufferIndex : 2
D/SubstituteAudioEffect﹕ timeProgress 46439
If you have any idea, please help me.
thank you.
Sravanthi_K_Intel
Hello there - Thanks for the question, but I'm afraid the information about the bug/error is not enough to understand the problem and its cause. Can you please give us information such as what product you used, what sample application you used etc? For example, to debug issues, we recommend customers use our sample applications or share their code with us with details. And also, please mention the product you are using too. In general, here is the information we request to understand the problem better - https://software.intel.com/en-us/forums/topic/531083
JIHOON_O_
I'm sorry, I totally forgot to describe information.
I use m4m(media for mobile) of Intel INDE to develop video editing application on Android OS.
And I subscribe media for mobile android samples in github(https://github.com/INDExOS/media-for-mobile)
The problem is audio effect sample in m4m android samples.
I've tried to change sample to add audio effect with mp3 format(audio/mpeg not only audio/mp4a-latm)
But It crashes with BufferOverflowException.
If you need more information, please let me know.
Thank you.
