3093 Discussions
Beta3 sample source sample_decode_s3d MFXVideoSession init failed
IDZ_A_Intel
command line and output is:
C:\\Program Files\\Intel\\Media SDK\\3.0.442.32245 Beta3\\samples\\_build\\Win32\\Debug>
sample_decode_s3d.exe mvc -i d:/test.mvc -o d:/out.yuv
Return on error: error code -3, c:\\program files\\intel\\media sdk\\3.0.442.32245 b
eta3\\samples\\sample_decode_s3d\\src\\pipeline_decode_s3d.cpp 435
Return on error: error code 1, c:\\program files\\intel\\media sdk\\3.0.442.32245 b
eta3\\samples\\sample_decode_s3d\\src\\sample_decode_s3d.cpp 170
But the binary sample_decode_s3d.exe Beta3 takes by itself running well, why?
IDZ_A_Intel
One possible explanation for this behavior could be your system's search path.Is theMedia SDK 3 Beta 3 bin directoryincluded? Is it before older versions of Media SDK?
You may also want to check whether the library path matches the type of build you did on the sample (Win32/x64). If you run thebinary sampleincluded with the installation the matching Media SDK software DLL is in the same directory so thepath is not used in the search.
Please let us know if this does not get you started. We will be glad to investigate further.
Jeff
IDZ_A_Intel
Thank you Jeff,the reason iswrong lingking version of libmfxsw32.dll, when i copy my build to bin folder, everything is right
