Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
CreateSwapChainForHwnd returns E_ACCESSDENIED
EricMao
First call into a new class succeeds, second call into a NEW class fails using the same HWND.
However, I'm unable to create a new window handle as a work around (CCTV switching in a single HWND).
The error is 'CreateSwapChainForHwnd returns E_ACCESSDENIED' on a second Class and Call using the same window handle.
A believe a DirectX resource / object has not been properly freed.
I believe the issue to be related to the following thread:
https://stackoverflow.com/questions/20556885/directx-11-createswapchainforhwnd-fails-with-e-accessdenied
And have subsequently called both:
D3D11Context->ClearState();
D3D11Context->Flush();
in the Close() function as recommended by Microsoft to no affect, similar to the stackoverflow thread above.
