Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3093 Discussions
Issue with Decoding H.264 Video Encoded in macOS Safari
enm10k
Our team is developing a program to process WebRTC video using libvpl.
Currently, we are encountering an issue with the decoding process.
Is this a bug? If not, we would like to know how to avoid it.
## Issue
When trying to decode H.264 video encoded in macOS Safari using libvpl, the decoder sometimes continues to return MFX_ERR_MORE_DATA.
## What We Checked
- This issue does not occur with H.264 video encoded in Chrome.
- The problematic data could be decoded correctly with libavcodec.
## Minimal Reproducible Example
We prepared the code and data to reproduce the issue in the following repository.
https://github.com/melpon/libvpl-more-data-issue
## What We Found
With the data in the above repository, the value of max_num_ref_frames changes from 5 to 9 when the frame size changes, and we suspect this may be the cause of the issue.
Starting processing from bin/frame_0076.h264, where max_num_ref_frames is 9, does not cause the issue.
## Environment
The issue reproduces in the following environment.
OS: Ubuntu 22.04
libvpl: v2.10.1
CPU: 12th Gen Intel® Core™ i5-1240P, Intel® Processor N100
Additionally, here are the versions of the browsers and OS used for testing:
OS: macOS 14.4.1 (23E224)
Safari: 17.4.1 (19618.1.15.11.14)
Chrome: 123.0.6312.107 (Official Build) (arm64)
