Decode Error
dong_x_
HI
     I have a H264 file.
     When i use "simple_decode" to decode on frame data, "DecodeFrameAsync" always return "MFX_ERR_MORE_DATA"
     "DecodeHeader" succeed, and return the right image width and height(2448* 2048).
    the file is the H264 bits.
     And I can decode it with FFmpeg.
451727
dong_x_
    I update the frame file.
    Please use this for test
451732
Surbhi_M_Intel
Can you please send us the media sdk analyzer and media tracer logs to debug this issue? System analyzer is a utility that analyzes the system and reports back Intel Media SDK related capabilities and tracer logs is a utility that performs runtime recording of Intel Media SDK API calls and parameters to a log file.You can find more details about the tools in the <installed folder>\Software Development Kit\Tools.
Also, I was able to decode the input you have send. cmd used
sample - sample_decode.exe h264 -i Downloads\123_frame\123.temp -o customer.yuv
tutorial - simple_decode.exe Downloads\123_frame\123.temp output.yuv
-Surbhi
