Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Dynamic change bitrate
fujianfang
  when I use " Intel MediaSDK 2022Q3 Release - 22.5.4" at 11th Gen Intel(R) Core(TM) i7-1165G7.**
use h264 encode, 720p5994,BufferSizeInKB set to 3500 at init, when I change bitrate from 27Mbps -> 32Mbps . m_pmfxENC->Reset faild, ret=-14 or ret=5. hevc don't have this issue.
Q1: Is there any way to avoid this error(ret=-14/ret = 5)?
when encode ret=-14 or ret=5, sometimes will cause sample_decode return -14(MFX_ERR_INCOMPATIBLE_VIDEO_PARAM).
I have add use LD_PRELOAD=/opt/intel/mediasdk/lib64/libmfx-tracer.so.1.35 to catch the debug log, please see at the attachment. you can search MFX_WRN_INCOMPATIBLE_VIDEO_PARAM.
I also meet this issue when use ONE VPL at 12th Gen Intel(R) Core(TM) i7-12700.
