Exception at encoding core, MFXVideoCORE_SyncOperation permanently returns MFX_ERR_UNKNOWN after it
OTorg
New Contributor III
Application pseudo code:
1. create session
2. create h264 encoder on that session, init it, prepare buffers
3. encode frames from raw nv12-file
4. flush encoder, wait for last output frame
5. release encoder and all resources, except session
6. goto 2
Input file and encoding parameters are the same on every cycle execution. Debug compillation, x86. MFX_IMPL_SOFTWARE only. imsdk 1.7.
After some time after application start (from several minutes to several days, in different runs) i got at debugger output:
"First-chance exception at 0x595798f3 in imsdk_h264enc.exe: 0xC0000005: Access violation reading location 0x000000c0."
And MFXVideoCORE_SyncOperation returns MFX_ERR_UNKNOWN after that, subsequent MFXVideoCORE_SyncOperation calls (with the same arguments) permanently return MFX_ERR_UNKNOWN.
Exception point details:
C:\PLANG\Intel\Media SDK 2013 R2\bin\win32\libmfxsw32.dll, offset 0x001988F3 from section ".text" begin
595798D7 mov ecx,dword ptr [edi+1D34h]
595798DD push edx
595798DE lea edx,[ecx+eax*2]
595798E1 mov eax,dword ptr [esi+20h]
595798E4 lea ecx,[eax+edx*2]
595798E7 mov edx,dword ptr [edi+34h]
595798EA mov ecx,dword ptr [edx+ecx*4]
595798ED mov eax,dword ptr [edi+1B94h]
595798F3 add ecx,dword ptr [eax+0C0h] *********** it is here *********
595798F9 mov edx,dword ptr [esi+3Ch]
595798FC push ecx
595798FD push edx
595798FE push edi
595798FF lea ecx,[ebp+0Bh]
59579902 mov edx,esi
PS:
Now, I realized that there is a little chance that problem is provoked by crt versions conflict (i got "LINK : warning LNK4098: defaultlib 'MSVCRT' conflicts with use of other libs" at build, because of debug application build).
I'll make own mfx_dispatch build with the same settings as at application (debug/mt-dll-crt/vs2010), use it to rebuild application, and run tests again.
I'll write the results here in a couple of days.
Petter_L_Intel
Hi dj_alek,
I've asked my colleague to get back to on this since he explored thie question at an earlier stage.
Regarding the SW DLL exception issue. We plan to resolve the issue in Media SDK 2014, which will be released at the end of this year.
Petter
celli4
I doubt this is your problem, but it's worth mentioning. I moved the hard disk from an Ivy Bridge system to a Haswell system, and I believe, because of it I got very infrequent but intermittent crashes in the IMSDK.  In my situation, upgrading to latest driver for the right architecture seemed to fix the problem.
OTorg
New Contributor III
Thanks, but: MFX_IMPL_SOFTWARE only + libmfxsw32.dll shipped with imsdk 1.7 (latest). So, nothing to update...
OTorg
New Contributor III
Got exception without recreating CEncoder instances.
I attach this simpler test application (a simple long-running h264 encoding).
Bernard
Valued Contributor I
Sometimes access violation can be due to calling exports of unmapped DLL.Can you upload a dump file?
OTorg
New Contributor III
mov eax, dword ptr [edi+1B94h]
add ecx, dword ptr [eax+0C0h] *** AV here, with eax=00000000 ***
I don't think it is unmapped DLL, it is more like an inaccurate code.
Dump attached.
PS:
You can examine these exceptions yourself. Put the files _input.nv12, imsdk_h264enc.exe and libmfxsw32.dll in one folder (download links: https://docs.google.com/file/d/0B8SCkOT4os4HNXVHdHpFT0gzYkk/edit?usp=sharing and https://drive.google.com/file/d/0B8SCkOT4os4HTHVacmllbHFuUG8/edit?usp=sharing). And run imsdk_h264enc.exe under windbg...
Zach_J_1
Intel mods, FYI I have a similar issue as well with a separate application:  http://software.intel.com/en-us/forums/topic/485411
I will be watching this closely!  Thanks.
OTorg
New Contributor III
And here are the test results from other machines. i7-4770 & i5-3330 both fell into AV, exception locations differ (see attachment) from the previously published here for the i7-3770 (or we simply have not got them yet on i7-3770). Plus, i7-4770 fell twice into infinite error returning from MFXVideoCORE_SyncOperation without any exception.
I would like to draw your attention once again: doing some other work on the computer concurrently with the test, leads to earlier exception raise.
Zach_J_1
After looking into my issue a bit more, I realized that I am having the same exact issue as this post.  The sync operation fails with MFX_ERR_UNKNOWN.
Bernard
Hi dj_alek
I will look tomorrow at dump files.I was busy trying to understand kernel dump files of HAXM BSOD.
Petter_L_Intel
I performed numerous runs (one of them 24h long) using the second code drop (imsdk_h264enc_v2.zip) you provided, but so far no errors or exceptions.
We will explore the new info you provided and execute some more runs with other workloads being executed concurrently.
Petter
OTorg
New Contributor III
Hi Peter
Got any results?
Bernard
I don't think it is unmapped DLL, it is more like an inaccurate code.>>>
Sorry for late answer.I was busy with programming projects and HAXM BSOD.
Yes I agree that the example above is not related to unmapped dll,but this snippet of code can be related.
558cf459 752f jne libmfxsw32!MFXVideoVPP_GetVPPStat+0x19191a (558cf48a)15558cf45b 0fb708 movzx ecx,word ptr [eax] ds:002b:05cabfa0=???? *********** it is here *********
Bernard
Hi dj_alek
Your minidump file is too small can you collect full dump?I need to see all loaded and referenced dll's by libmfxsw32.dll.Please use .dump /ma
command in windbg.
Petter_L_Intel
Hi dj_alek,
Today I encountered the issue "First-chance exception . 0xC0000005: Access violation reading location 0x000000c0" for the first time after running the workload during a few 10-20 hour chunks. Unfortunately I was not able to capture any deeper debug info due to some config issues with the machine I'm using.
Some observations however:
- I'm only able to hit the error state if I run the Release build of the workload. Despite 50h+ runs, I never encountered the issue in Debug build.
- As you said, there seems to be a relation to if the CPU is busy with other tasks or not.
- During one run I did encounter a state where SyncOperation() returned MFX_WRN_IN_EXECUTION indefinitely. No exception thrown. I'm trying to reproduce this case again to try to find the root cause.   BTW: on this topic. Have you tried changing the time delay value you use with the SyncOperation() call?  Does setting that value to, for instance, 1000 instead or 10 make any difference?
I will try to reproduce the issue again shortly.
Petter
OTorg
New Contributor III
At last! Hurrah!
When I stumbled upon the issue for the first times, it was precisely a debug build of the test application. Has debug version also been observed under concurrent workloads in your tests?
No, I haven't. I'll try 1000.
OTorg
New Contributor III
iliyapolak wrote:
Please use .dump /ma command in windbg.
I don't think it's worth rummaging through the dumps as long as the developers were able to catch the problem. Thanks, Bernard.
Bernard
dj_alek wrote:
Quote:
iliyapolak wrote:Please use .dump /ma command in windbg.
You are welcome.
Bernard
dj_alek wrote:
I noticed that if I'm doing some other work on the computer concurrently with the test, then exception appears earlier.
What workload exactly?
OTorg
New Contributor III
Any. Text editor, visual studio edit/build, photo editor, browser, torrent.
Comical situation was on one machine. I ran the test for the night. Looked at windbg/procexp next morning - no exceptions, CPU load is high - ok. Then clicked on the windows start menu button - and exception occured at that moment.
Bernard
>>> CPU load is high - ok. Then clicked on the windows start menu button - and exception occured at that moment.>>>
I agree that this is very strange situation.I think that in order to properly investigate that issue kernel debugger must be hooked up to the target(debugee).In case of clicked button I would suspect KeSwapContext and maybe any function related to context switching for not cleaning up registers when the some user mode thread's stack is swapped out.Somehow old context is preserved when control is returned and  libmfxsw32.dll function is called the exception occures.It could be something different also.
OTorg
New Contributor III
iliyapolak wrote:
... kernel debugger ... KeSwapContext ... cleaning up registers ...
I think it is much more prosaic. And error lies somewhere in libmfxsw32 code. Stake on inaccurate critical sections usage:)
