3084 Discussions
How can I install Intel® Media Server Studio 2017 on CentOS7.2
tetsuji_o_
I'll try to install Intel® Media Server Studio 2017 on CentOS7.2.
Environment is as follows.
model name         : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
$ cat /etc/redhat-release
CentOS Linux release 7.2.1511 (Core)
$ arch
x86_64
$ cat /proc/version
Linux version 3.10.0-327.28.3.el7.x86_64 (builder@kbuilder.dev.centos.org) (gcc version 4.8.3 20140911 (Red Hat 4.8.3-9) (GCC) ) #1 SMP Thu Aug 18 19:05:49 UTC 2016
I've read some documents. But it seems like that Media Server Studio doesn't be installed.
The below is my doing stemps.
$ sudo yum -y groupinstall "Development Tools"
sudo yum -y install pciutils net-tools autoconf automake cmake freetype-devel gcc gcc-c++ git libtool make mercurial nasm pkgconfig zlib-devel mesa-dri-drivers wget bc
sudo usermod -a -G video build
su build
tar zxvf MediaServerStudioEssentials2017.tar.gz
cd MediaServerStudioEssentials2017
tar zxvf SDK2017Production16.5.tar.gz
cd SDK2017Production16.5/CentOS
tar zxvf install_scripts_centos_16.5-55964.tar.gz
su
./install_sdk_CentOS.sh
reboot
What's wrong? If you know a solution, let me know it.
Bests,
tetsuji_o_
Hi Zachary,
Thank you for your comment.
 i7-3770 CPU is 2nd Generation CPU. I found that Media server studio 2017 and 2015 are not supported the CPU.
Tetsuji
Jiandong_Z_Intel
Hi There,
Have you refer to Getting Started Guide - Linux* Installation ?
you also can find this pdf in your MSS package.
you need verify your installation with MSDK sample. you can refer "Verifying correct installation " in Getting Started Guide - Linux* Installation .
Zachary
tetsuji_o_
Hi Zachary,
Tetsuji
