Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3092 Discussions
How to choose proper initial_pool_size for FFmpeg qsv encoder
ykhong
I am testing HEVC encoding with
    i9-12900K (UHD Graphics 770 iGPU)
    31.0.101.5186_101.5234 WHQL Certified
I used FFmpeg hevc_qsv and it require initialized HWFramesContext
since it does not support dynamic pool size
i have to set pool size with hw_frames_ctx->initial_pool_size = ...
In libavcodec/qsv.c qsv_frame_alloc has proper code that using NumFrameSuggested
and registered to mfxFrameAllocator::Alloc but this function is never called
So how do i select proper pool size for QSV encoding with FFmpeg?
and i cant figure out why mfxFrameAllocator::Alloc is not called
(documentation said it is called twice when MFXVideoENCODE_Init is called)
(It seems that tutorial also call mfxFrameAllocator::Alloc manually...)
