Is EndOfStream deprecated?
BMart1
New Contributor II
The reference manual advises using EndOfStream​ with MFXVideoENCODE_Reset but EndOfStream​ is deprecated according to the mfxExtCodingOption documentation. Who's wrong?
Mark_L_Intel1
Hi Bruno,
Thanks so much for checking and reporting our document errors, this is a big help for us since the document errors sometimes are hard to find.
Yes, I can confirm the error you point out:
In the latest reference manual,
Page 16: it says: "The application must set the initial encoding configuration flag EndOfStream of the mfxExtCodingOption structure to OFF to avoid inserting an End of Stream (EOS) marker into the bitstream."
while in page 57, it says the field EndOFStream of mfxExtCodingOption was deprecated.
I will file a bug to fix it.
Mark
BMart1
New Contributor II
Thanks, Mark.
Bruno
Mark_L_Intel1
Hi Bruno,
Apology for the long delay, we have a fix to this issue and it is in GitHub now.
The related document was removed:
https://github.com/Intel-Media-SDK/MediaSDK/pull/2502/files
Let me know if you have questions.
Mark
