Is there any possible to integrate Media SDK into Microsoft Direct Show?
I__Lin
I have installed and test Intel Media SDK and few sample codes like sample_decode to test. I would like to use Intel Media SDK feature such as hardware decode (like Quick Sync) to integrate into our own Direct Show filters. Is there any possible to do that? Or is there any sample project we could reference in Intel Media SDK sample?
Johnny Lin
Mark_L_Intel1
Hi Johnny,
Are you asking if you want to use Direct Show to do the rendering?
You might check our tutorial code at the following page:
https://software.intel.com/en-us/intel-media-server-studio/code-samples
You can check the package https://software.intel.com/sites/default/files/mediasdk-tutorials-0.0.3.zip to see if it has the rendering example you need.
Mark
I__Lin
Hi Mark,
Thanks for the reply. We want to make our own Direct Show decoder filter, and integrate Media SDK into decoder to decode h.264 stream. I will check the tutorial first. If there is any update or question, I will post here to discuss.
Johnny Lin
