3084 Discussions
Looking for examples of using oneVPL VPP filters
Vasilev__Evgenii
Hello ,
I am looking for code examples of using oneVPL VPP filters, such as a VPP Denoising filter (https://spec.oneapi.io/versions/latest/elements/oneVPL/source/API_ref/VPL_structs_vpp.html#structmfx_ext_v_p_p_denoise2) or other VPP filters. Can you help and add code example using VPP Denoising? I tried to find any examples, but my searches were unsuccessful. I think such example would be useful to many people who start their work with oneVPL.
Thank you for your attention!
AlekhyaV_Intel
Thank you for posting in Intel Communities. We are sorry to inform you that, currently, we don't have any code samples for VPP Denoising. Here is the link for code samples which are currently available for oneVPL- https://github.com/oneapi-src/oneVPL
However, if you would like to work on VPP Denoising, Intel Media SDK has some code samples. For your reference, we have provided the link below:
https://github.com/Intel-Media-SDK/MediaSDK Please refer the readme files for the denoise algorithm usage.
Hope this helps!
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Alekhya
AlekhyaV_Intel
Has the solution provided helped? Could you please give us an update regarding this issue?
Alekhya
AlekhyaV_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
