MFX_ERR_INCOMPATIBLE_VIDEO_PARAM with MPEG2 Encoding and low Bitrate
SDeut
I experience an error:
while calling <MFXVideoENCODE_Init> if mfx.TargetKbps is below a certain value. Settings are appropriate for regular DVD Video PAL, MPEG2.
Values for TargetKbps above 0x0120 (means ca. 4500 MBit/sec Video) give MFX_ERROR_NONE, values below result in the error code above.
Is this a bug or do I have change other settings as well?
Lee_g_
did you try to change codec profile and level?
SDeut
yes, I tried to switch from
 MFX_PROFILE_MPEG2_MAIN@MFX_LEVEL_MPEG2_MAIN
to
MFX_PROFILE_MPEG2_MAIN@MFX_LEVEL_MPEG2_LOW
MFX_PROFILE_MPEG2_SIMPLE@MFX_LEVEL_MPEG2_MAIN
MFX_PROFILE_MPEG2_SIMPLE@MFX_LEVEL_MPEG2_LOW
but makes no difference.
