3093 Discussions
MFXVideoCORE_SyncOperation error when using VPP and Encoder
Kayu_M_
There is a computer that MFXVideoCORE_SyncOperation returns MFX_ERR_ABORTED in our encoding application. This computer used to work fine before, but now returns an error after a Windows update. No error is returned on other computers in the same application.
When the Intel Media SDK sample program(sample_encode.exe) is executed, MFX_ERR_DEVICE_FAILED is returned if VPP is not executed, and MFX_ERR_UNKNOWN is returned if VPP is executed. The driver is up to date. Executing the sample program on other computers does not return such errors.
Our application uses VPP.
What is the cause of this error? Is there a workaround?
Nikita_P_Intel1
What is your Windows version?
Could you try to install the latest graphics driver via exe installer? You can download it here
https://downloadcenter.intel.com/download/28991/Intel-Graphics-Windows-10-DCH-Drivers?product=80939
Kayu_M_
It's Windows10.
After installing the latest graphic driver provided by the PC manufacturer, no error return occurs.
