Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3089 Discussions
Maximum bit rate obtainable with HW encoder HEVC and XAVC
francescoBLT
Hi
I'm attempting to determine maximum bit rate using HW encoder HEVC and XAVC.
Reading the code :
https://github.com/Intel-Media-SDK/MediaSDK/blob/master/_studio/mfx_lib/shared/src/mfx_h264_enc_common_hw.cpp#L600
it seems that maximum bit rate for AVC is 360Mbit/s so I can't create XAVC class 300 @60P (bit rate of 600Mbit/s). Correct ?
I didn't find any similar function for HEVC. What's  maximum bit rate obtainable using HW encoder?
I need to encode 4K@60 (3840x2160@60P); can I reach 600Mbit or more ?
regards
JyothisV_Intel
Good day to you.
Have you observed this while encoding any raw video?
Are you trying this with the latest version of the sample_encode present in the link: https://github.com/oneapi-src/oneVPL/tree/ca5bbbb057a6e84b103aca807612afb693ad046c/tools/legacy/sample_encode.
Reference to build oneVPL: https://github.com/oneapi-src/oneVPL/blob/master/INSTALL.md
Further more, we are checking with the development team and will let you know what are maximum bitrates possible for both H264(AVC) and H265(HEVC) codec and whether XAVC class 300 @60P with a bitrate of 600 Mbit/s is supported by oneVPL/MediaSDK.
Can you provide us with the following information in order to understand your query better:
1. Hardware/OS Versions
2. Are you using MediaSDK or oneVPL. The version of MediaSDK or oneVPL
3. Commands used for encoding along with a sample test video to replicate it from our side.
Jyothis V James
