Monochrome and 10 bits avc encode
James_C_5
Hi All,
I would like to test avc encode with chroma only video.
I try to set ChromaFormat  = MFX_CHROMAFORMAT_MONOCHROME with high profile, but MFXVideoENCODE_Init returns MFX_ERR_INVALID_VIDEO_PARAM.
Does Intel support chroma only on avc encode?
BTW, does Intel still not support 10 bits avc encode?
Thank you.
James
Anna_B_Intel
Hi James,
Unfortunately MFX_CHROMAFORMAT_MONOCHROME is not supported by AVC encoder as well as 10bit.
Best wishes,
Anna
James_C_5
Hi Anna,
Thanks for your reply.
James
James_C_5
Hi Anna,
I have another question regarding monochrome encode.
Does Intel support monochrome HEVC encode?
I try to set following parameters. It doesn't work, and MFXVideoENCODE_Init also returns MFX_ERR_INVALID_VIDEO_PARAM.
CodecProfile = MFX_PROFILE_HEVC_REXT
GeneralConstraintFlags = MFX_HEVC_CONSTR_REXT_MAX_12BIT | MFX_HEVC_CONSTR_REXT_MAX_10BIT | MFX_HEVC_CONSTR_REXT_MAX_8BIT | MFX_HEVC_CONSTR_REXT_MAX_422CHROMA | MFX_HEVC_CONSTR_REXT_MAX_420CHROMA | MFX_HEVC_CONSTR_REXT_MAX_MONOCHROME | MFX_HEVC_CONSTR_REXT_LOWER_BIT_RATE
Thank you & Best Regards,
James
Anna_B_Intel
Hi James,
MFX_CHROMAFORMAT_MONOCHROME is not supported by HEVC encoder.
Best wishes,
Anna
James_C_5
Hi Anna,
Thank you for your help.
James
