Hi ,
I have installed latest drivers 5500, 2016 Media Server Studio and Intel Media SDK 2016 r2.
Downloaded the latest samples from GITHUB: https://github.com/Intel-Media-SDK/samples
have built sample_encode in release mode, win64 and able to see the sample_encode.exe in _build folder.
When I try to execute following command:
sample_encode.exe h264 -i test.mp4 -o output.mp4 -w 1280 -h 720 -b 1800 -u quality -f 29
a file is generated but That has zero frames and of size 2.5 MB.
Can anyone help me in resolving the issue.
Sudhaakr
Hi Sudhakar,
Media SDK and it's samples are targeted towards working with elementary streams for different codecs like .264/.265. For you input, use any 3rd party tool to demux the content and later pass through media sdk samples.
For sample_encode, input should be a raw stream i.e. yuv content and encode it to h264 elementary stream.
For sample_decode, input should be an elementary steam and the output will be in yuv (for example - out.yuv)
You can run the binaries to see cmd line suggestions.
Hope it helps.
Surbhi
