Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3084 Discussions
Onevpl code is failing with sts=MFX_ERR_UNSUPPORTED
Sushant35
Hi Support
I am trying to run oneVPL sample code on my system by following this link .
https://www.intel.com/content/www/us/en/developer/articles/technical/overview-of-onevpl-examples-and-tools.html#gs.4uvx45
Please find below command i am running
sample_encode mpeg2 -hw -i content/cars_320x240.i420 -w 320 -h 240 -o output.bit
and error i am getting
CONFIGURE LOADER: required implementation: hw
CONFIGURE LOADER: required implementation mfxAccelerationMode: MFX_ACCEL_MODE_VIA_VAAPI
libva info: VA-API version 1.14.0
libva info: User environment variable requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_14
libva info: va_openDriver() returns 0
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), AllocFrames, Query (for encoder) failed at /home/sushant/MISC/oneVPL/tools/legacy/sample_encode/src/pipeline_encode.cpp:1003
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), ResetMFXComponents, AllocFrames failed at /home/sushant/MISC/oneVPL/tools/legacy/sample_encode/src/pipeline_encode.cpp:2078
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), Init, ResetMFXComponents failed at /home/sushant/MISC/oneVPL/tools/legacy/sample_encode/src/pipeline_encode.cpp:1860
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), main, pPipeline->Init failed at /home/sushant/MISC/oneVPL/tools/legacy/sample_encode/src/sample_encode.cpp:1898
Frame number: 0
Encoding fps: -nan
Please help me to find right solution to it .
Sushant35
please find system_analyzer details below:
Looking for GPU interfaces available to OS...
FOUND: /dev/dri/renderD128
GPU interfaces found: 1
Available implementation details:
Implementation #0: mfxhw64
Library path: /usr/lib/x86_64-linux-gnu/libmfxhw64.so.1.35
ApiVersion: 1.35
Impl: MFX_IMPL_TYPE_HARDWARE
ImplName: mfxhw64
MediaAdapterType: MFX_MEDIA_UNKNOWN
VendorID: 0x8086
DeviceID: 0x3E92
GPU name: unknown (arch=na codename=na)
PCI BDF: FFFFFFFF:FFFFFFFF:FFFFFFFF.FFFFFFFF
PCI RevisionID: 0xFFFF
DRMRenderNodeNum: 128
DeviceName: mfxhw64
Sushant35
I am running it on linux Ubuntu environement
Also please found vainfo command implementation
error: XDG_RUNTIME_DIR not set in the environment.
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
vainfo: VA-API version: 1.14 (libva 2.12.0)
vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 22.3.1 ()
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSliceLP
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSliceLP
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
AlekhyaV_Intel
Thank you for posting in Intel Communities. Thank you for sharing all the details.
We didn't encounter any error when we tried sample_encode(oneVPL 2023.0.0) with cars_320x240.i420 video file given in Content folder with the command you provided. Please find the commands which worked for us:
sample_encode mpeg2 -hw -i cars_320x240.i420 -w 320 -h 240 -o output.bit
sample_encode mpeg2 -hw -i cars_320x240.i420 -w 320 -h 240 -o output.mpeg2
sample_encode.exe mpeg2 -i cars_320x240.i420 -o out-with-carsi420.mpeg2 -w 320 -h 240 -b 15000 -u speed -hw
Please provide us the below information so that we could debug your issue further.
  1. Your exact OS details
  2. Your Processor details/Entire system details
  3. Did you make any changes to the oneVPL sample? If yes, please share the code file.
Alekhya
Sushant35
Hi Alekhya
Thanks for your response , i have not made any changes to one VPL sample .
i tried with your set of commands but no success.
Please find my os details below
Linux ubuntu22-devel 5.15.0-58-lowlatency #64-Ubuntu SMP PREEMPT Fri Jan 6 03:36:28 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
and GPU details
*-display
description: VGA compatible controller
product: CoffeeLake-S GT2 [UHD Graphics 630]
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
logical name: /dev/fb0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 resolution=1280,720
resources: irq:127 memory:a0000000-a0ffffff memory:90000000-9fffffff ioport:4000(size=64) memory:c0000-dffff
and Implementation details
ApiVersion: 1.35
VendorImplID: 0x0000
ImplName: mfxhw64
License:
Version: 1.2
Keywords: MSDK,x64
VendorID: 0x8086
mfxAccelerationModeDescription:
Version: 1.0
mfxPoolPolicyDescription:
Version: 1.0
mfxDeviceDescription:
DeviceID: 3e92/0
Version: 1.1
mfxDecoderDescription:
Version: 0.0
mfxEncoderDescription:
Version: 0.0
mfxVPPDescription:
Version: 0.0
NumExtParam: 0
Total number of implementations found = 1
i hope i am not missing any implementation ?
Thanks & Regards
Sushant Kaushik
Sushant35
Hi Alekhya
and GPU details
*-display
physical id: 2
version: 00
width: 64 bits
clock: 33MHz
ApiVersion: 1.35
ImplName: mfxhw64
License:
Version: 1.2
Keywords: MSDK,x64
VendorID: 0x8086
Version: 1.0
Version: 1.0
DeviceID: 3e92/0
Version: 1.1
Version: 0.0
Version: 0.0
mfxVPPDescription:
Version: 0.0
NumExtParam: 0
Thanks & Regards
Sushant
Sushant35
Hi Alekhya,
it is able to run succesfully in case of jpeg images
please find below output
sample_encode jpeg -q 100 -hw -i /usr/local/share/vpl/examples/content/cars_320x240.mjpeg -w 320 -h 240 -o output.bit
libva info: VA-API version 1.19.0
Encoding Sample Version 8.4.27.0
Input file format YUV420
Output video JPEG
Source picture:
Resolution 320x240
Crop X,Y,W,H 0,0,320,240
Destination picture:
Resolution 320x240
Frame rate 30.00
Bit rate(Kbps) 0
Gop size 100
Ref dist 0
Ref number 0
Idr Interval 0
Target usage quality
Memory type vaapi
Media SDK impl hw
Media SDK version 1.35
Processing started
Frame number: 1
Encoding fps: 71
Processing finished
but with other codec it is failing with above mentioned error
sample_encode h264 -hw -i /usr/local/share/vpl/examples/content/cars_320x240.mjpeg -w 320 -h 240 -o output.bit
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), AllocFrames, Query (for encoder) failed at /home/sushant/MISC/msdk/samples/sample_encode/src/pipeline_encode.cpp:966
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), ResetMFXComponents, AllocFrames failed at /home/sushant/MISC/msdk/samples/sample_encode/src/pipeline_encode.cpp:2076
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), Init, ResetMFXComponents failed at /home/sushant/MISC/msdk/samples/sample_encode/src/pipeline_encode.cpp:1857
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), main, pPipeline->Init failed at /home/sushant/MISC/msdk/samples/sample_encode/src/sample_encode.cpp:1787
Frame number: 0
Encoding fps: -0
Sushant35
also to correct myself i have implementation of MediaSDK on my system not onevpl as i am running on Coffee lake on linux.
AlekhyaV_Intel
Thanks for sharing all the details with us. Mjpeg is already an encoded file. Trying to encode it again might result in an error or a corrupted video file. Please check the below readme file where the required input files are YUV420 & NV12 and expected output file(compressed/encoded) would be in the formats: h264, h264, mpeg-2, jpeg/Motion Jpeg, HEVC, etc.
Try encoding a yuv420 or nv12 video files as shown in the below screenshots:
If this resolves your issue, make sure to accept this as solution. This helps others with similar issue. Thank you!
Alekhya
Sushant35
Hi @AlekhyaV_Intel Alekhya
Thanks for your response , i am already using NV12 and YUV420 and getting those errors from Day 1 .
one new thing came sample encode is only working with -cqp and when i remove it this error comes again Any idea on this?
/usr/share/mfx/samples/sample_encode h264 -w 176 -h 144 -f 30 -cqp -qpi 30 -qpp 30 -qpb 30 -qsv-ff -i AUD_MW_E.yuv -o encoded_AUD_MW_E.264
found on below page
https://github.com/Intel-Media-SDK/MediaSDK/wiki/Intel-media-stack-on-Ubuntu
 Can you please help me understanding that why is is successful with -cqp flag
  and for h265 it is still failing with MFX_ERR_DEVICE_FAILED?
Sushant35
also please help me if i have to download additional configuration or software
below is output of vpl-inspect
ApiVersion: 1.35
ImplName: mfxhw64
License:
Version: 1.2
Keywords: MSDK,x64
VendorID: 0x8086
Version: 1.0
Version: 1.0
DeviceID: 4e71/0
Version: 1.1
Version: 0.0
Version: 0.0
mfxVPPDescription:
Version: 0.0
NumExtParam: 0
AlekhyaV_Intel
Apologies for the delay and thanks for sharing all the details.
As per your response, you have mentioned that you're getting the same error even while trying to encode with YUV420 & NV12.
  1. Could you please share the commands you used along with error screenshots?
  2. And, Please share the modified encode sample if any.
And regarding your second query along with -cqp flag, we are working on this internally and would get back to you soon with an update.
Alekhya
AlekhyaV_Intel
Could you please give us the information that we asked you for?
Meanwhile, Regarding your query on -cqp flag, CQP is a Constant Quantization Parameter(CQP BRC) Bitrate control method. The Quantization Parameter controls the amount of compression for every macroblock in a frame. Large values mean that there will be higher quantization, more compression, and lower quality. Lower values mean the opposite. QP ranges from 0 to 51 in H.264.
[-cqp] - constant quantization parameter (CQP BRC) bitrate control method (by default constant bitrate control method is used), should be used along with -qpi, -qpp, -qpb.
[-qpi] - constant quantizer for I frames (if bitrate control method is CQP). In range [1,51]. 0 by default, i.e.no limitations on QP.
[-qpp] - constant quantizer for P frames (if bitrate control method is CQP). In range [1,51]. 0 by default, i.e.no limitations on QP.
[-qpb] - constant quantizer for B frames (if bitrate control method is CQP). In range [1,51]. 0 by default, i.e.no limitations on QP.
Alekhya
AlekhyaV_Intel
We asked few queries about your issue. Could you please answer them?
And regarding the information we gave on -cqp flag, did it help you with your doubts?
Please give us an update on this?
Alekhya
AlekhyaV_Intel
We have not heard back from you about the additional queries we asked. If you need any further information, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
