QuickSync multiple HD sources
Adam_N_
We would like to be able to efficiently record 5 simultaneous Full HD streams using i7 6700K. Is it possible? What are the i7 6700K GPU limitations? Our understanding is that QuickSync encoder can handle such scenario. We are using MPlatform SDK:
http://www.medialooks.com/mplatform/
Which is basically a wrapper around Intel Media SDK. However when going above 2 sources, CPU load goes to 100% and we're unable to reliable record high quality videos. Can anyone please help and guide me to some other possible solutions in order to achieve our goal? What other options are possible to get 5 simultanous Full HD stream recorded?
-- Thanks, Adam
Jiandong_Z_Intel
Hi Adam,
I want to known more detail regarding this issue.
Which OS are you using ? Linux or Windows ?
If windows, can you share log from system_analyzer tool located at (mediasdk/tools/analyzer) ? This will help provide us your system details.
Which codec are you using ? h264 or others ?
Have you tested with MSDK samples (https://software.intel.com/en-us/intel-media-server-studio-support/code-samples) ?
Zachary
