Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Re: Re:Questions about installing OneVPL
nmihara
Thank you for your reply.
Where can I find a sample to verify that OneVPL is working correctly?
Please let me know specifically which site and which sample I should check.
DiyaN_Intel
You need to follow the steps one by one to get oneVPL working in your system after checking the system requirements.
Once the oneVPL is installed in your system, you can find the samples of oneVPL and follow the steps mentioned in it to execute the samples.
If you still have doubts please let us know.
If this resolves your issue, make sure to accept this as a solution. This would help others with a similar issue. Thank you!
Diya
