Sharing VA Surfaces with media sdk
ahmed__shakeeb
I want to use media sdk to perform denoising on linux. The problem I have is that I have VASurfaceID which i want to give to the media sdk to perform denoising. Is there any good way to convert this VASurfaceID to mfxFrameSurface1 or something similar so that I can use Media SDK?
Mark_L_Intel1
Hi Shakeeb,
Sorry for the late response, did you solved this problem yet?
We should be able to support VASurfaceID, could you check the sample code of our Media SDK open source project? Here might be a good start point and you might trace the API from here:
https://github.com/Intel-Media-SDK/MediaSDK/blob/7f93c075850798d8b5555eec02f517d2cbd85dcf/samples/sample_common/src/vaapi_allocator.cpp
https://github.com/Intel-Media-SDK/MediaSDK/blob/dfdce26488c5a6e443a56fedce02b7a496dcbd0b/samples/sample_common/src/vaapi_utils.cpp
Our sample code has 2 configurations for memory usage: system memory and video memory; VASurfaceID should be on the path for video memory.
Hope this helps.
Mark
