Unable to load Screen Capture plugin
Borger__Austin
I'm trying to test the screen capture plugin, which is installed on my system at <media_sdk>/bin/win32/22d62c07e672408fbb4cc20ed7a053e4.  However, after initializing MFX to the latest supported hardware implementation (1.20 on this machine), a call to MFXVideoUSER_Load results in MFX_ERR_NOT_FOUND.  See the code excerpt below:
version.Major = 1;
version.Minor = 20;
res = MFXInit(MFX_IMPL_HARDWARE, &version, &session);
// Check for error...
res = MFXVideoUSER_Load(session, &MFX_PLUGINID_CAPTURE_HW, 1);
// res == -9 is true
Here is the result of running the system analysis tool:
Intel(R) Media Server Studio 2016 R2 - System Analyzer (32-bit)
The following versions of Media SDK API are supported by platform/driver
[opportunistic detection of MSDK API > 1.19]:
        Version Target  Supported       Dec     Enc
        1.0     HW      Yes             X       X
        1.0     SW      Yes             X       X
        1.1     HW      Yes             X       X
        1.1     SW      Yes             X       X
        1.2     HW      Yes             X       X
        1.2     SW      Yes             X       X
        1.3     HW      Yes             X       X
        1.3     SW      Yes             X       X
        1.4     HW      Yes             X       X
        1.4     SW      Yes             X       X
        1.5     HW      Yes             X       X
        1.5     SW      Yes             X       X
        1.6     HW      Yes             X       X
        1.6     SW      Yes             X       X
        1.7     HW      Yes             X       X
        1.7     SW      Yes             X       X
        1.8     HW      Yes             X       X
        1.8     SW      Yes             X       X
        1.9     HW      Yes             X       X
        1.9     SW      Yes             X       X
        1.10    HW      Yes             X       X
        1.10    SW      Yes             X       X
        1.11    HW      Yes             X       X
        1.11    SW      Yes             X       X
        1.12    HW      Yes             X       X
        1.12    SW      Yes             X       X
        1.13    HW      Yes             X       X
        1.13    SW      Yes             X       X
        1.14    HW      Yes             X       X
        1.14    SW      Yes             X       X
        1.15    HW      Yes             X       X
        1.15    SW      Yes             X       X
        1.16    HW      Yes             X       X
        1.16    SW      Yes             X       X
        1.17    HW      Yes             X       X
        1.17    SW      Yes             X       X
        1.18    HW      Yes             X       X
        1.18    SW      Yes             X       X
        1.19    HW      Yes             X       X
        1.19    SW      Yes             X       X
        1.20    HW      Yes             X       X
        1.20    SW      Yes             X       X
        1.21    SW      Yes             X       X
        1.22    SW      Yes             X       X
        1.23    SW      Yes             X       X
Graphics Devices:
        Name                                         Version             State
        Intel(R) Iris(TM) Pro Graphics P6300         20.19.15.4835       Active
        VMware SVGA 3D                               8.15.1.60           Active
System info:
        CPU:    Intel(R) Xeon(R) CPU E3-1285L v4 @ 3.40GHz
        OS:     Microsoft Windows 10 Enterprise
        Arch:   64-bit
Installed Media SDK packages (be patient...processing takes some time):
        Intel(R) Media SDK 2017 R1
        Samples for Intel(R) Media SDK 2017 for Windows*
Installed Media SDK DirectShow filters:
Installed Intel Media Foundation Transforms:
        Intel(R) Quick Sync Video H.264 Encoder MFT : {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}
Analysis complete... [press ENTER]
And here are the contents of the plugin's config file:
PluginVersion = 1
APIVersion    = 279 //0x0117
FileName32    = "mfxplugin32_screen_capture.dll"
FileName64    = "mfxplugin64_screen_capture.dll"
Type          = 01 //decode
CodecID       = "CAPT"
Default       = 0
Running the screen_decode.exe sample yields a similar result.
What could be causing the API not to find the plugin?
Borger__Austin
I've updated to the latest driver and that didn't fix the problem.  Also as a sanity check, I've printed out the plugin UID, which matches the folder name.  I have one other plugin installed, MFX_PLUGINID_CAMERA_HW.  If I ask to load that plugin, the MFXVideoUSER_Load function returns successfully.
The problem also persists in a 64-bit build.
Green__Max
Did you find a way to fix it? I have a similar problem.
