3088 Discussions
Unexpected MFX_ERR_NOT_ENOUGH_BUFFER error during h.264 encoding
Benjamin_Blanc
We use Media SDK to do software h.264 video encoding.
We switched from Media SDK 2012 R2 to Media SDK 2014 R2. Long run tests revealed a problem: after a period (several hours, not constant), encoding stops working, no more video frames are encoded.
After investigations, we found that the function MFXVideoENCODE::EncodeFrameAsync(...) returns -5, i.e. MFX_ERR_NOT_ENOUGH_BUFFER
The documentation stipulates that this error happens when: The bitstream buffer size is insufficient.
We have output the state of the bitstream buffer when the error occurred and here are some:
- Encoding Error: -5 - encode buffer state: max: 9375000, current: 1041, offset: 0
- Encoding Error: -5 - encode buffer state: max: 9375000, current: 585, offset: 0
- Encoding Error: -5 - encode buffer state: max: 9375000, current: 1284, offset: 0
- Encoding Error: -5 - encode buffer state: max: 9375000, current: 1024, offset: 0
- Encoding Error: -5 - encode buffer state: max: 9375000, current: 81, offset: 0
- Encoding Error: -5 - encode buffer state: max: 9375000, current: 859, offset: 0
As you can see, the bitstream buffer seems large enough to handle a new frame. Our code doesn't change and it worked perfectly with Media SDK 2012.
We have currently a workaround which consist to destroy and re-create the bitstream buffer and reinitialize the buffer data length with: (mfxVideoParam)m_MFXEncParams.mfx.BufferSizeInKB * 1000
However it doesn't seem to be an expected behavior, so I would like to know if it is something that has already been remarked?
Here is our initialization code and the code added to skirt the problem:
Init parameters:
    m_MFXEncParams.mfx.CodecId                    = MFX_CODEC_AVC;
    m_MFXEncParams.mfx.TargetUsage                = MFX_TARGETUSAGE_BEST_SPEED ;
    m_MFXEncParams.mfx.RateControlMethod        = MFX_RATECONTROL_VBR;
    m_MFXEncParams.mfx.GopRefDist                = 1;
    m_MFXEncParams.AsyncDepth                    = 1;
    m_MFXEncParams.mfx.FrameInfo.FourCC            = MFX_FOURCC_NV12;
    m_MFXEncParams.mfx.FrameInfo.ChromaFormat    = MFX_CHROMAFORMAT_YUV420;
    // specify memory type
    m_MFXEncParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY;
    /*Initializing Extcoding options with msxdecframebuffering = 1 to reduce decode latency*/
    mfxExtBuffer *extBuffersInit[1];
    mfxExtCodingOption extCO;
    memset( &extCO, 0, sizeof( extCO)) ;
    extCO.Header.BufferId = MFX_EXTBUFF_CODING_OPTION;
    extCO.Header.BufferSz = sizeof(mfxExtCodingOption);
    extCO.MaxDecFrameBuffering = 1;
    extBuffersInit[0] = reinterpret_cast<mfxExtBuffer*>(&extCO);
    m_MFXEncParams.NumExtParam = 1;
    m_MFXEncParams.ExtParam = extBuffersInit;
    m_MFXEncParams.mfx.NumRefFrame  = 1;
    //Initialization of the specific encoding params
    m_MFXEncParams.mfx.FrameInfo.Width  = ALIGN_16(m_StreamFormat.GetWidth()) ;
    m_MFXEncParams.mfx.FrameInfo.Height = ALIGN_16(m_StreamFormat.GetHeight()) ;
    m_MFXEncParams.mfx.FrameInfo.CropX = 0;
    m_MFXEncParams.mfx.FrameInfo.CropY = 0;
    m_MFXEncParams.mfx.FrameInfo.CropW = m_StreamFormat.GetWidth() ;
    m_MFXEncParams.mfx.FrameInfo.CropH = m_StreamFormat.GetHeight() ;
    m_MFXEncParams.mfx.TargetKbps                = (mfxU16)m_StreamFormat.GetBitrate() ; // in Kbps
    m_MFXEncParams.mfx.FrameInfo.FrameRateExtN    = (mfxU32)m_StreamFormat.GetFps() ;
    m_MFXEncParams.mfx.FrameInfo.FrameRateExtD    = 1 ;
    m_MFXEncParams.mfx.GopPicSize                = m_MFXEncParams.mfx.FrameInfo.FrameRateExtN*2 ;
    m_MFXEncParams.mfx.FrameInfo.PicStruct        = MFX_PICSTRUCT_PROGRESSIVE;
Encode:
    do
        mfxError = m_MFXEncoder->EncodeFrameAsync( FKFC, surface, &m_MFXEncodedBs, &sp);
        if (mfxError == MFX_ERR_NONE)
            break ;
        if (mfxError == MFX_WRN_DEVICE_BUSY)
            Sleep(1) ;
        else
            CStdString dbgStr ;
            dbgStr.Format( L"- Encoding Err: %d - encode buffer state: max: %d, current: %d, offset: %d\n", mfxError, m_MFXEncodedBs.MaxLength, m_MFXEncodedBs.DataLength, m_MFXEncodedBs.DataOffset) ;
            OutputDebugString( dbgStr.GetString()) ;
            if (mfxError == MFX_ERR_NOT_ENOUGH_BUFFER)
                //resize the buffer to the needed size
                delete [] m_MFXEncodedBs.Data ;
                memset( &m_MFXEncodedBs, 0, sizeof( m_MFXEncodedBs)) ;
                m_MFXEncodedBs.Data = new unsigned char[m_MFXEncParams.mfx.BufferSizeInKB * 1000] ;
                m_MFXEncodedBs.MaxLength = m_MFXEncParams.mfx.BufferSizeInKB * 1000;
            return errEncode ;
    while (true) ;
Computer:
    CPU: Intel Core i7-2600
    OS: Windows 7 Pro 64 bits
    Graphic Drivers: latest
    SDK Library version used: 32 bits
Thank you,
Benjamin
Harshdeep_B_Intel
Can you update to MSDK 2015  new version API 1.13 which is available as part of INDE now from https://software.intel.com/en-us/intel-inde. Also if you can send us the logs from System analyzer and tracer which will help us further look into the issue of buffer reset. Also are you running a 4k video? As I see HW is a 2nd generation SKU.  Logs from the tools will provide us more information.
Benjamin_Blanc
Hi Harsh,
Thanks for your fast answer! I will download the new SDK and try to reproduce with it. If I succeeded, I will use the system analyzer and tracer to create logs.
The video resolution is only 640x480.
Have a good day,
Benjamin
Benjamin_Blanc
Hi Harsh,
I have updated to the new version of the MSDK (1.13) from Inde and performed several days of testing without modifying the code.
And it works! I have never seen again the 'not enough' buffer error. It seems that there was probably a problem with the 2014R2 version of MSDK.
Thanks for your time,
Benjamin
Harshdeep_B_Intel
Yes, with every new release of MSDK API, we have fixes and new implementaion. Glad to know you don't see the issue.
