3090 Discussions
What's the maximum compression ratio for h264 and h265 encoding now?
yu__luo
Well, in my situation, my encoding configuration is:
resolution=3840x2160
target bitrate=500kbps
fps=30
codec=h264
RC mode=CBR
And the real encoded bitrate is 4000kbps. And I found some sentences in this forum that said the limit of the compression ratio is 500x.
I can understand the real bitrate is mismatched now. But I want to make sure that the limit of the compression ratio is still 500x? Is h265 encoding the same?
BTW, there is a parameter named BitrateLimit in CodingOptionValue. I tried to set it to false, and nothing changed.
Dmitry_E_Intel
For AVC case, min bitrate logic is here: https://github.com/Intel-Media-SDK/MediaSDK/blob/master/_studio/mfx_lib/shared/src/mfx_h264_enc_common_hw.cpp#L3504
Are you sure you turned off BitrateLimit? I mean did you set BitrateLimit=MFX_CODINGOPTION_OFF (not "=false")?
As for HEVC, I don't think MediaSDK has similar limit logic.
BTW, you always can get internal (actual) MSDK parameters by GetVideoParam function and check if MSDK made any tuning to initialization parameters.
Dmitry_E_Intel
