Zero-sized .stf file generated from ITAC
kang__myeongseok
I am actually trying to use Intel Trace Analyzer and Collector (ITAC) to profile my MPI code written in Fortran.
The code does execute MPI_init at first and MPI_finalize at the end.
Following the thread of [ https://software.intel.com/en-us/forums/intel-clusters-and-hpc-technology/topic/517182 ] and
[ http://mvapich.cse.ohio-state.edu/static/media/mvapich/mvapich2-2.2rc1-userguide.html#x1-890006.21 ],
I have learned that using either LD_PRE_LOAD prior to run or adding '-itac' option for compiling and linking works in my case.
The problem is that, although I was able to obtain .stf and .prot files, the size of .stf file is zero, thus unable to open it with ITAC.
In addition, I have also noticed that when I try to run the executable file compiled using '-itac' option, it works only for the single node case, and hangs for multiple nodes case.
For your information, I'm using "Intel® Parallel Studio XE 2018 Update 3" for compilers, mvapich2.2.2-qlc-intel18 for MPI library, which is compatible with ITAC from check_compatibility.c test, and CentOS 6.4 for the OS.
Any helpful comment will be deeply appreciated.
Mark_L_Intel1
This is the forum to support Intel Media SDK, please use the other forum to discuss your issue.
Mark
kang__myeongseok
Oh sorry about that.
Could you let me know how to delete this post?
I do not see delete button here..
