Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
build FFmpeg with oneVPL, libvpl>=2.6 not found
shenuo
I try to build ffmpeg with oneVPL, but get this error:
ERROR: libvpl >= 2.6 not found
I use ffmpeg (6.0) and oneAPI 2023 on windows 11 visual studio 2022, (i7-12700H,A770).
the command line for run configure is:
./configure --toolchain=msvc --enable-gpl --enable-libx264 --enable-libx265 --enable-libvpl --enable-shared
by the way, if set toolchain=icl,  get error like
C compiler test failed
I run this command line by these steps:
Intel oneAPI command prompt for intel64 for visual studio 2022->
msys2 (need to install msys2 ) window , run configure
JaideepK_Intel
Thank you for posting in Intel communities.
We were able to reproduce your issue on our Linux machines and we are working on it internally. We will get back to you with an update.
Jaideep
clytle
I have the same issue.
Perhaps a clue...  I ran the following:
> wget -O- https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB | gpg --dearmor | sudo tee /usr/share/keyrings/oneapi-archive-keyring.gpg > /dev/null
> echo "deb [signed-by=/usr/share/keyrings/oneapi-archive-keyring.gpg] https://apt.repos.intel.com/oneapi all main" | sudo tee /etc/apt/sources.list.d/oneAPI.list
> sudo apt install intel-basekit
> PATH="$HOME/bin:$PATH" PKG_CONFIG_PATH="$HOME/ffmpeg_build/lib/pkgconfig" ./configure --prefix="$HOME/ffmpeg_build" --pkg-config-flags="--static" --extra-cflags="-I$HOME/ffmpeg_build/include" --extra-ldflags="-L$HOME/ffmpeg_build/lib" --extra-libs="-lpthread -lm" --ld="g++" --bindir="$HOME/bin" --enable-gpl --enable-gnutls --enable-libaom --enable-libass --enable-libfdk-aac --enable-libfreetype --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libvmaf --enable-nonfree --enable-libvpl
RESULT:
shenuo
   actually I can solve this by moving oneVPL related files to the usr/local, lib, bin ,include and packge-config path.
fan123
Did this problem has been solved? I meet the same question and am looking for the solution.
JaideepK_Intel
Glad to know that your issue is resolved. Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
MrKay
Facing the same issue on Ubuntu 22.04, installed all the latest VPL packages, yet cannot build ffmpeg from intel cartwheels:
apt install -y \
intel-opencl-icd intel-level-zero-gpu level-zero \
intel-media-va-driver-non-free libmfx1 libmfxgen1 libvpl2 \
libegl-mesa0 libegl1-mesa libegl1-mesa-dev libgbm1 libgl1-mesa-dev libgl1-mesa-dri \
libglapi-mesa libgles2-mesa-dev libglx-mesa0 libigdgmm12 libxatracker2 mesa-va-drivers \
mesa-vdpau-drivers mesa-vulkan-drivers va-driver-all vainfo hwinfo clinfo
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
clinfo is already the newest version (3.0.21.02.21-1).
hwinfo is already the newest version (21.72-1).
intel-media-va-driver-non-free is already the newest version (23.2.4-682~22.04).
level-zero is already the newest version (1.11.0-649~22.04).
libegl-mesa0 is already the newest version (23.2.0.20230712.1-2073~22.04).
libegl1-mesa is already the newest version (23.2.0.20230712.1-2073~22.04).
libegl1-mesa-dev is already the newest version (23.2.0.20230712.1-2073~22.04).
libgbm1 is already the newest version (23.2.0.20230712.1-2073~22.04).
libgl1-mesa-dev is already the newest version (23.2.0.20230712.1-2073~22.04).
libgl1-mesa-dri is already the newest version (23.2.0.20230712.1-2073~22.04).
libglapi-mesa is already the newest version (23.2.0.20230712.1-2073~22.04).
libgles2-mesa-dev is already the newest version (23.2.0.20230712.1-2073~22.04).
libglx-mesa0 is already the newest version (23.2.0.20230712.1-2073~22.04).
libigdgmm12 is already the newest version (22.3.7-678~22.04).
libmfx1 is already the newest version (23.2.2-682~22.04).
libmfxgen1 is already the newest version (23.2.4-682~22.04).
libvpl2 is already the newest version (2023.3.0.0-682~22.04).
libxatracker2 is already the newest version (23.2.0.20230712.1-2073~22.04).
mesa-va-drivers is already the newest version (23.2.0.20230712.1-2073~22.04).
mesa-vdpau-drivers is already the newest version (23.2.0.20230712.1-2073~22.04).
mesa-vulkan-drivers is already the newest version (23.2.0.20230712.1-2073~22.04).
va-driver-all is already the newest version (2.19.0.2-66~u22.04).
vainfo is already the newest version (2.19.0.2-1~u22.04).
intel-level-zero-gpu is already the newest version (1.3.26918.9).
intel-opencl-icd is already the newest version (23.30.26918.9).
export PKG_CONFIG_PATH=/opt/intel/mediasdk/lib/pkgconfig
root@gpu02 ~/cartwheel-ffmpeg/ffmpeg # ./configure \
--prefix=/usr/local/ \
--extra-ldflags=-L/usr/local/lib \
--extra-ldflags=-L./libmp3lame/.libs/libmp3lame.a \
--enable-libvpl \
--enable-vaapi \
--enable-opencl \
--disable-debug \
--enable-gnutls \
--enable-libvorbis \
--enable-libvpx \
--enable-libdrm \
--enable-gpl \
--cpu=native \
--enable-libfdk-aac \
--enable-libx264 \
--enable-libx265 \
--extra-libs=-lpthread \
--enable-nonfree \
--enable-libass \
--enable-libfreetype \
--enable-libmp3lame \
--enable-libopus \
--enable-libwebp \
--enable-libzimg \
--enable-shared \
--enable-nonfree
MrKay
