no 'object' file generated
Shiwani_A_
Hello ,
I installed the INDE and am trying to build the SDK example sample_full_transcode from visual basic but I am getting following two errors :
Error C2220 warning treated as error - no 'object' file generated sample_full_transcode C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\deprecated\sample_full_transcode\src\muxer_wrapper.cpp 76
Warning C4456 declaration of 'sts' hides previous local declaration sample_full_transcode C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\deprecated\sample_full_transcode\src\muxer_wrapper.cpp 76
And when I am doing the compile option of visual basic to w3 this error gets removed but another comes up which is :
LNK1104 cannot open file 'libmfx_d.lib' sample_full_transcode LINK 1
Please help me in this issue.
Shiwani
Shaojuan_Z_Intel
There is FFmpeg dependency in sample_full_transcode, and the FFmpeg version that is validated with Samples is version 2.0.2. Please refer to Media Samples Guide for more information.
Regarding to "libmfx_d.lib" link error, I guess you were trying to build it in Debug mode, this is a known issue in the current release, and will be fixed in the next release. To work around this issue, you can try to build it in Release mode instead, or, in Debug mode, you can just change libmfx_d.lib to libmfx.lib here: Property Pages->Configuration Properties->Linker->Input. Please let us know if this doesn't work. Thanks!
Shaojuan_Z_Intel
Shiwani_A_
Hello ,
Thanks for the reply that solves me the above mentioned issue . But on building it gives me 10 warnings :
libmfx.lib(main.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib(main.obj)' or at 'C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\_build\x64\Debug\vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_critical_section.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib(mfx_critical_section.obj)' or at 'C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\_build\x64\Debug\vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_dispatcher.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib(mfx_dispatcher.obj)' or at 'C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\_build\x64\Debug\vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_dxva2_device.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib(mfx_dxva2_device.obj)' or at 'C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\_build\x64\Debug\vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_function_table.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib(mfx_function_table.obj)' or at 'C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\_build\x64\Debug\vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_library_iterator.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib(mfx_library_iterator.obj)' or at 'C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\_build\x64\Debug\vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_load_dll.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib(mfx_load_dll.obj)' or at 'C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\_build\x64\Debug\vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_load_plugin.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib(mfx_load_plugin.obj)' or at 'C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\_build\x64\Debug\vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_plugin_hive.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib(mfx_plugin_hive.obj)' or at 'C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\_build\x64\Debug\vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_win_reg_key.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib(mfx_win_reg_key.obj)' or at 'C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\_build\x64\Debug\vc80.pdb'; linking object as if no debug info
sample_full_transcode.vcxproj -> C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\deprecated\sample_full_transcode\..\..\_build\x64\Debug\sample_full_transcode.exe
Please it would be helpful if you explain me this error and suggest some workarounds  .
Thanks ,
Shiwani
Shaojuan_Z_Intel
Those LNK4099 errors are related to some compilers, you can ignore those warning messages. Seems that sample_full_transcode.exe was generated successfully, were you able to run it?
Shiwani_A_
Hi Shaojuan ,
I run the generated executables but on running it is giving me following error :
C:\Users\Parag\Documents\Intel Media Samples 6.0.0.49\_bin\x64>sample_full_transcode.exe  -i file.mp4  -o out.mp4  -v:b 2000 -acodec:copy  -hw
pipeline_profile.cpp :169 [INFO] Track 0   : Video enabled
pipeline_profile.cpp :164 [INFO] Track 1   : Audio enabled
pipeline_manager.cpp :88 [INFO] Input     : file.mp4
pipeline_manager.cpp :89 [INFO] NumTracks : 2
pipeline_manager.cpp :90 [INFO] Output    : out.mp4
session_storage.cpp :47 [INFO] Audio library of specified version was not found
session_storage.cpp :70 [ERROR] pVideoSession->Init(m_impl, &m_ver), sts=-3
main.cpp :71 [ERROR] Exiting...
Can you explain me this error and please provide a workaround .
Regards ,
Shiwani
Surbhi_M_Intel
Hi Shiwani,
I don't see this issue at our end. To debug the issue, can you please send us the system details - run system analyzer tool located @ C:\Intel\media_sdk_6.0.**\tools\mediasdk_sys_analyzer\ and let us know the o/p to check the system configuration.
Also, send us the mp4 file you are using to run the sample, so that we can produce the same issue at our end.
Please note that sample_full_transcode has a ffmpeg 2.0.2 version dependency to run the code, this is explained in the media sample guide present in samples package.
Surbhi
Shiwani_A_
Hi Surbhi ,
The attach media is not authorising me to attach the file . So i am just copying the content of the  system analyser file .
Intel® Media Software Development Kit
System Analyzer
Overview
Features
System Requirements
Using the Software
Known Limitations
Legal Information
Overview
The Intel® Media SDK System Analyzer utility analyzes the system and reports back Intel Media SDK related capabilities, driver and components status. The tool can be used to determine environment issues with regards to specific version of Intel Media SDK or Intel® HD Graphics driver.
Features
When executed, the tool reports back the following information in clear text:
  1. 1.    Intel® Media SDK API version support matrix determining if software or hardware implementation is available. If the hardware device is located on non-default adapter, the Intel graphics adapter number is specified (if active).
  2. 2.    Enumerates the installed graphic adapters. Active adapter is marked.
  3. 3.    Provides basic system information, such as CPU name and OS type.
  4. 4.    Lists installed Intel Media SDK packages/versions.
  5. 5.    Lists the installed Intel Media SDK Microsoft* DirectShow* filters.
  6. 6.    Lists the installed Intel Media SDK Microsoft* Media Foundation Transforms (MFT).
  7. 7.    Provides some tips for solutions in case either software or hardware implementation does not work.
System Requirements
See <install-folder>\mediasdk_release_notes.rtf for system requirements.
Using the Software
Execute “<install-folder>\tools\mediasdk_sys_analyzer\win32\sys_analyzer.exe” or
<install-folder>\tools\mediasdk_sys_analyzer\x64\sys_analyzer.exe”
The tool will start reporting system status immediately. When done the user can exit the tool by pressing any key.
Note: Querying the system for installed Intel® Media SDK packages may take some time. Please be patient.
Example Output:
Intel Media SDK System Analyzer (64 bit)
The following versions of Media SDK API are supported by platform/driver:
        Version Target  Supported       Dec     Enc
        1.0     HW      Yes             X       X
        1.0     SW      Yes             X       X
        1.1     HW      Yes             X       X
        1.1     SW      Yes             X       X
        1.3     HW      Yes             X       X
        1.3     SW      Yes             X       X
        1.4     HW      Yes             X       X
        1.4     SW      Yes             X       X
        1.5     HW      No
        1.5     SW      Yes             X       X
        1.6     HW      No
        1.6     SW      Yes             X       X
        1.7     HW      No
        1.7     SW      No
Graphics Devices:
        Name                         Version             State
        Intel(R) HD Graphics 3000    9.17.10.2857        Active
System info:
        CPU:    Intel(R) Core(TM) i5-2540M CPU @ 2.60GHz
        OS:     Microsoft Windows 7 Enterprise
        Arch:   64-bit
Installed Media SDK packages (be patient...processing takes some time):
        Intel« Media SDK 2013 (x64)
Installed Media SDK DirectShow filters:
  Intel« Media SDK H.264 Encoder :
    C:\Program Files\Intel\Media SDK 2013\samples\_bin\x64\h264_enc_filter.dll
  Intel« Media SDK AAC Decoder :
    C:\Program Files\Intel\Media SDK 2013\samples\_bin\x64\imc_aac_dec_ds.dll
Installed Intel Media Foundation Transforms:
  Intel« Hardware VC-1 Decoder MFT : {059A5BAE-5D7A-4C5E-8F7A-BFD57D1D6AAA}
  Intel« Media SDK H.264 Decoder MFT : {0855C9AC-BC6F-4371-8954-671CCD4EC16F}
Analysis complete... [press ENTER]
A few command line options are also available:
  -skipPackage : Skip query for installed Media SDK packages
  -skipDShow   : Skip query for installed DirectShow filters
  -skipMFT     : Skip query for installed MFTs
  -skipWait    : Do not wait for user key press on analysis completion
Known Limitations
  • •    The tool may not be able to provide a full report in case Microsoft* Windows* Management Instrumentation (WMI) service is not running. If you encounter this issue, please explore if it is possible to activate this feature via Microsoft Windows Control Panel settings on your machine.
The video file was a normal mp4 file . Info regarding that file is :
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'f.mp4':
Metadata:
    major_brand     : mp42
    minor_version   : 0
    compatible_brands: isommp42
    creation_time   : 2015-05-29 11:56:22
  Duration: 00:00:59.72, start: 0.000000, bitrate: 530 kb/s
   Stream #0:0(und): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 431 kb/s, 25 fps, 25 tbr, 25 tbn, 50 tbc (default)
    Metadata:
      handler_name    : VideoHandler
    Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 96 kb/s (default)
    Metadata:
      handler_name    : IsoMedia File Produced by Google, 5-11-2011
Thanks ,
Shiwani
