Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3093 Discussions
oneVPL MFXVideoDECODE_DecodeFrameAsync return MFX_ERR_NOT_INITIALIZED(-8)
parksh
OS : Windows 10
CPU : 11th Gen Intel(R) Core(TM) i7-11700
oneVPL MFXVideoDECODE_DecodeFrameAsync() -> return MFX_ERR_NOT_INITIALIZED
# sample_code
int main(int argc, char *argv[]) {
    bool isDrainingDec = false;
    bool isDrainingEnc = false;
    bool isStillgoing = true;
    bool isFailed = false;
    FILE *sink = NULL;
    FILE *source = NULL;
    mfxBitstream bs_dec_in = {};
    mfxBitstream bs_enc_out = {};
    mfxFrameSurface1 *dec_surface_out = NULL;
    mfxSession session = NULL;
    mfxStatus sts = MFX_ERR_NONE;
    mfxStatus sts_r = MFX_ERR_NONE;
    mfxSyncPoint syncp = {};
    mfxU32 framenum = 0;
    mfxVideoParam encodeParams = {};
    mfxVideoParam stream_info = {};
    Params cliParams = {};
    // variables used only in 2.x version
    mfxConfig cfg[4];
    mfxVariant cfgVal[4];
    mfxLoader loader = NULL;
    mfxU8 timeout_count;
    //Parse command line args to cliParams
    if (ParseArgsAndValidate(argc, argv, &cliParams, PARAMS_DECODE) == false) {
          Usage();
          return 1; // return 1 as error code
    if (MFX_IMPL_TYPE_SOFTWARE != cliParams.implValue.Data.U32) {
          printf("Only software implementation is supported\n");
          return 1;
    source = fopen(cliParams.infileName, "rb");
    VERIFY(source, "Could not open input file");
    sink = fopen(OUTPUT_FILE, "wb");
    VERIFY(sink, "Could not create output file");
    // Initialize VPL session
    loader = MFXLoad();
    VERIFY(NULL != loader, "MFXLoad failed -- is implementation in path?");
    // Implementation used must be the type requested from command line
    cfg[0] = MFXCreateConfig(loader);
    VERIFY(NULL != cfg[0], "MFXCreateConfig failed")
    sts =
          MFXSetConfigFilterProperty(cfg[0], (mfxU8 *)"mfxImplDescription.Impl", cliParams.implValue);
    VERIFY(MFX_ERR_NONE == sts, "MFXSetConfigFilterProperty failed for Impl");
    // Implementation must provide an HEVC encoder
    cfg[1] = MFXCreateConfig(loader);
    VERIFY(NULL != cfg[1], "MFXCreateConfig failed")
    cfgVal[1].Type = MFX_VARIANT_TYPE_U32;
    cfgVal[1].Data.U32 = MFX_CODEC_HEVC;
    sts = MFXSetConfigFilterProperty(
          cfg[1],
          (mfxU8 *)"mfxImplDescription.mfxEncoderDescription.encoder.CodecID",
          cfgVal[1]);
    VERIFY(MFX_ERR_NONE == sts, "MFXSetConfigFilterProperty failed for encoder CodecID");
    // Implementation used must provide API version 2.2 or newer
    cfg[2] = MFXCreateConfig(loader);
    VERIFY(NULL != cfg[2], "MFXCreateConfig failed")
    cfgVal[2].Type = MFX_VARIANT_TYPE_U32;
    cfgVal[2].Data.U32 = VPLVERSION(MAJOR_API_VERSION_REQUIRED,     MINOR_API_VERSION_REQUIRED);
    sts = MFXSetConfigFilterProperty(cfg[2],
            (mfxU8 *)"mfxImplDescription.ApiVersion.Version",
            cfgVal[2]);
    VERIFY(MFX_ERR_NONE == sts, "MFXSetConfigFilterProperty failed for API version");
    // Implementation must provide a JPEG decoder
    cfg[3] = MFXCreateConfig(loader);
    VERIFY(NULL != cfg[3], "MFXCreateConfig failed")
    cfgVal[3].Type = MFX_VARIANT_TYPE_U32;
    cfgVal[3].Data.U32 = MFX_CODEC_AVC;
              cfg[3],
              (mfxU8 *)"mfxImplDescription.mfxDecoderDescription.decoder.CodecID",
              cfgVal[3]);
    VERIFY(MFX_ERR_NONE == sts, "MFXSetConfigFilterProperty failed for decoder CodecID");
    sts = MFXCreateSession(loader, 0, &session);
              "Cannot create session -- no implementations meet selection criteria");
    // Print info about implementation loaded
    ShowImplementationInfo(loader, 0);
    // Initiate bs_dec_in for decode input stream and parse basic stream information (input width and height)
    // in : session, source
    // out: bs_dec_in, stream_info
    // Prepare input bitstream and start decoding
    bs_dec_in.MaxLength = BITSTREAM_BUFFER_SIZE;
    bs_dec_in.Data = (mfxU8 *)calloc(bs_dec_in.MaxLength, sizeof(mfxU8));
    VERIFY(bs_dec_in.Data, "Not able to allocate input buffer");
    bs_dec_in.CodecId = MFX_CODEC_AVC;
    //Pre-parse input stream
    sts = ReadEncodedStream(bs_dec_in, source);
    VERIFY(MFX_ERR_NONE == sts, "Error reading bitstream\n");
    stream_info.mfx.CodecId = MFX_CODEC_AVC;
    stream_info.IOPattern = MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
    sts = MFXVideoDECODE_DecodeHeader(session, &bs_dec_in, &stream_info);
    VERIFY(MFX_ERR_NONE == sts, "Error decoding header\n");
    // Prepare bitstream for encode output and encode params
    // in : stream_info.mfx.FrameInfo.Width, stream_info.mfx.FrameInfo.Height
    // out: bs_enc_out, encodeParams
    bs_enc_out.MaxLength = BITSTREAM_BUFFER_SIZE;
    bs_enc_out.Data = (mfxU8 *)calloc(bs_enc_out.MaxLength, sizeof(mfxU8));
    encodeParams.mfx.CodecId = MFX_CODEC_HEVC;
    encodeParams.mfx.TargetUsage = MFX_TARGETUSAGE_BALANCED;
    encodeParams.mfx.TargetKbps = TARGETKBPS;
    encodeParams.mfx.RateControlMethod = MFX_RATECONTROL_VBR;
    encodeParams.mfx.FrameInfo.FrameRateExtN = FRAMERATE;
    encodeParams.mfx.FrameInfo.FrameRateExtD = 1;
    //encodeParams.mfx.FrameInfo.FourCC = stream_info.mfx.FrameInfo.FourCC;
    //encodeParams.mfx.FrameInfo.ChromaFormat = stream_info.mfx.FrameInfo.ChromaFormat;
    if (MFX_IMPL_SOFTWARE == cliParams.impl) {
          encodeParams.mfx.FrameInfo.FourCC = MFX_FOURCC_I420;
    else {
          encodeParams.mfx.FrameInfo.FourCC = MFX_FOURCC_NV12;
    encodeParams.mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420;
    encodeParams.mfx.FrameInfo.CropW = stream_info.mfx.FrameInfo.Width;
    encodeParams.mfx.FrameInfo.CropH = stream_info.mfx.FrameInfo.Height;
    encodeParams.mfx.FrameInfo.Width = ALIGN16(encodeParams.mfx.FrameInfo.CropW);
    encodeParams.mfx.FrameInfo.Height = ALIGN16(encodeParams.mfx.FrameInfo.CropH);
    encodeParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY;
    // Initialize the encoder
    sts = MFXVideoENCODE_Init(session, &encodeParams);
    VERIFY(MFX_ERR_NONE == sts, "Could not initialize Encode");
    printf("Transcoding %s -> %s\n", cliParams.infileName, OUTPUT_FILE);
    while (isStillgoing == true) {
          sts = MFX_ERR_NONE;
          // Read input stream for decode
          if (isDrainingDec == false) {
                  if (sts != MFX_ERR_NONE) // No more data to read, start decode draining mode
                          isDrainingDec = true;
           // Decode MJPEG stream
           if (isDrainingEnc == false) {
                   timeout_count = 0;
                   do {
                            sts = MFXVideoDECODE_DecodeFrameAsync(session,
                                            (isDrainingDec == true) ? NULL : &bs_dec_in,
                                            NULL,
                                            &dec_surface_out,
                                            &syncp);
                            // From API version 2.5,
                            // When the internal memory model is used,
                            // MFX_WRN_ALLOC_TIMEOUT_EXPIRED is returned when all the surfaces are currently in use and timeout set by mfxExtAllocationHints for allocation of new surfaces through functions DecodeFrameAsync expired.
                             // Repeat the call in a few milliseconds.
                             // For more information, please check oneVPL API documentation.
                             if (sts == MFX_WRN_ALLOC_TIMEOUT_EXPIRED) {
                                     if (timeout_count > MAX_TIMEOUT_COUNT) {
                                              sts = MFX_ERR_DEVICE_FAILED;
                                              break;
                                      else {
                                              timeout_count++;
                                              sleep(WAIT_5_MILLISECONDS);
                                              continue;
                              else
                                   break;
                    } while (1);
hello-transcode.exe -hw -i input.h264
    Implementation details:
        ApiVersion: 2.3
        Implementation type: HW
        AccelerationMode via: D3D11
        DeviceID: 4c8a/0
        Path:  C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_e648bb2a2af8e9de\libmfx64-gen.dll
    Transcoding input.h264 -> out.h265
---> MFXVideoDECODE_DecodeFrameAsync return MFX_ERR_NOT_INITIALIZED(-8)
Why do I get MFX_ERR_NOT_INITIALIZED(-8) error when encoding with AVC/HEVC codec?
Thank you in advance for your reply.
ThasneemV_Intel
We have observed that you made some changes in the code, and the "MFX_ERR_NOT_INITIALIZED" error occurs when the session is not correctly initialized. Currently, the hello-transcode sample in oneVPL focuses on converting a mjpeg video stream to h265 video format.
However, there is no existing sample that specifically addresses the transcoding of h264 to h265. Could you please try transcoding a mjpeg video file instead of an AVC video?
Thasneem Vazim
ThasneemV_Intel
We have not heard back from you. Could you please give us an update?
Thasneem Vazim
parksh
I'm sorry for late reply
I will try transcoding a mjpeg video file instead of an AVC video
thank you
ThasneemV_Intel
Thanks for the update.
Kindly let us know if we can stop monitoring this thread if there are no issues.
Thasneem Vazim
parksh
You may close the case.
Thanks again for your help.
