Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3088 Discussions
oneVPL swdec fails with MFX_ERR_ABORTED at DecodeFrameAsync()
gonta
Intel OneVPL version: 2023.0.0
Windows10
Visual Studio 2022
I'm developing decoder software based on sample_decode which I downloaded from https://github.com/oneapi-src/oneVPL .
My app receives AVC/HEVC stream, then split it into GOP units, and put them into CDecodingPipeline::RunDecoding().
Once I got MFX_ERR_MORE_DATA, put another GOP as so on.
HW decoder works fine, but SW decoder does not decode any frame and return MFX_ERR_MORE_DATA on 2nd call and results MFX_ERR_ABORTED on 3rd call.
How can I work around this error?
I modified  sample_decode  so that this situation can be reproduced.
  • HW codec works fine
    Warning - unable to create logfile C:\onevpldispatcher.log
    Log output will be sent to stdout
    function: MFXCreateConfig (enter)
    function: LoaderCtxVPL::AddConfigFilter (enter)
    function: LoaderCtxVPL::AddConfigFilter (return)
    function: MFXCreateConfig (return)
    function: MFXSetConfigFilterProperty (enter)
    function: MFXSetConfigFilterProperty (return)
    CONFIGURE LOADER: required implementation: hw
    CONFIGURE LOADER: required implementation mfxAccelerationMode: MFX_ACCEL_MODE_VIA_D3D11
    CONFIGURE LOADER: Use dispatcher's low-latency mode
    function: MFXCreateSession (enter)
    message:  low latency mode enabled
    function: LoaderCtxVPL::LoadLibsLowLatency (enter)
    function: LoaderCtxVPL::LoadLibsLowLatency (return)
    function: LoaderCtxVPL::QueryLibraryCaps (enter)
    function: LoaderCtxVPL::QueryLibraryCaps (return)
    function: LoaderCtxVPL::CreateSession (enter)
    function: LoaderCtxVPL::CreateSession (return)
    function: MFXCreateSession (return)
    Loaded Library configuration:
        Version: 1.0
        ImplName: mfx-gen
        Adapter number : 0
        Adapter type: integrated
    Loaded module path: C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_9671054d3bbcb1b5\libmfxhw64.dll
    pretending that aspect ratio is 1:1
    Decoding Sample Version 8.4.27.0
    Input video     AVC
    Output format   NV12
    Input:
      Resolution    1280x960
      Crop X,Y,W,H  0,0,1280,960
    Output:
      Resolution    1280x960
    Frame rate      1.00
    Memory type             system
    MediaSDK impl           hw_d3d11
    MediaSDK version        1.35
    Decoding started
    Frame number:  150, fps: 131.517, fread_fps: 0.000, fwrite_fps: 233.132
    [sk] call m_FileReader->Reset()
    Frame number:  300, fps: 153.265, fread_fps: 0.000, fwrite_fps: 214.777
    Frame number:  450, fps: 183.200, fread_fps: 0.000, fwrite_fps: 245.750
    Decoding finished
    function: LoaderCtxVPL::UnloadAllLibraries (enter)
    function: LoaderCtxVPL::UnloadAllLibraries (return)
    function: LoaderCtxVPL::FreeConfigFilters (enter)
    function: LoaderCtxVPL::FreeConfigFilters (return)
    E:\skudo\oneVPL-master\tools\out\build\x64-Debug\legacy\sample_decode\sample_decode.exe (プロセス 21728) は、コード 0 で終了しました。​
  • SW codec fails with MFX_ERR_ABORTED
    CONFIGURE LOADER: required implementation: sw
    CONFIGURE LOADER: required implementation mfxAccelerationMode: MFX_ACCEL_MODE_NA
    function: MFXEnumImplementations (enter)
    function: LoaderCtxVPL::BuildListOfCandidateLibs (enter)
    function: LoaderCtxVPL::BuildListOfCandidateLibs (return)
    function: LoaderCtxVPL::CheckValidLibraries (enter)
    function: LoaderCtxVPL::CheckValidLibraries (return)
    function: LoaderCtxVPL::PrioritizeImplList (enter)
    function: LoaderCtxVPL::PrioritizeImplList (return)
    function: LoaderCtxVPL::UpdateValidImplList (enter)
    function: LoaderCtxVPL::UpdateValidImplList (return)
    function: LoaderCtxVPL::QueryImpl (enter)
    function: LoaderCtxVPL::QueryImpl (return)
    function: MFXEnumImplementations (return)
    message:  low latency mode disabled
        Version: 2.7
        ImplName: oneAPI VPL CPU Implementation
        Adapter number : -1
    Loaded module path: C:\Program Files (x86)\Intel\oneAPI\vpl\latest\bin\libvplswref64.dll
    Input video     AVC
    Output format   IYUV
    Input:
      Resolution    1280x960
    Output:
      Resolution    1280x960
    Frame rate      1.00
    Memory type             system
    MediaSDK impl           sw
    MediaSDK version        2.7
    Decoding started
    Frame number:  150, fps: 47.876, fread_fps: 0.000, fwrite_fps: 338.849
    Frame number:  150, fps: 47.867, fread_fps: 0.000, fwrite_fps: 338.849
    [ERROR], sts=MFX_ERR_ABORTED(-12), CDecodingPipeline::RunDecoding, DecodeFrameAsync returned error status at pipeline_decode.cpp:1980
    Frame number:  150, fps: 47.859, fread_fps: 0.000, fwrite_fps: 338.849
    [ERROR], sts=MFX_ERR_ABORTED(-12), CDecodingPipeline::RunDecoding, Unexpected error!! at pipeline_decode.cpp:2100
    [ERROR], sts=MFX_ERR_ABORTED(-12), main, Pipeline.RunDecoding failed at sample_decode.cpp:901
    function: MFXDispReleaseImplDescription (enter)
    function: LoaderCtxVPL::ReleaseImpl (enter)
    function: LoaderCtxVPL::ReleaseImpl (return)
    function: MFXDispReleaseImplDescription (return)
    E:\skudo\oneVPL-master\tools\out\build\x64-Debug\legacy\sample_decode\sample_decode.exe (プロセス 21872) は、コード -12 で終了しました。​
