pipeline with 'mfxh264dec' gives larger end-to-end latency than 'avh264_dec'
Jiang__Dou
Problem:
With the same H264 RTP sender stream,  receiver pipeline with 'mfxh264dec' gives larger latency (30~60ms) than pipeline with ‘avdec_h264.
In my application, end-to-end latency is critical.
Since mfxh264dec with HW acceleration has less CPU usage than avdec_h264,
it would be great if mfxh264dec could give the (almost) same latency as avdec_264.
Plarform:
Win10,  VS2017,  gstreamer-1.16,  Media SDK 2017
gstreamer MSDK plugin from:
https://github.com/intel/gstreamer-media-SDK.git
(Built with OpenGL support using VS2017)
Note 'mfxh264dec' is built WITH OpenGl support:
C:\Users\UI>gst-inspect-1.0 --gst-plugin-load=C:\gst_MSDK_intel\gst-mfx-build_msvc\gst\mfx\gstmfx.dll mfxh264dec
Factory Details:
  Rank                     primary + 3 (259)
  Long-name                MFX H264 decoder
  Klass                    Codec/Decoder/Video
  Description              An MFX-based H264 video decoder
  Author                   Ishmael Sameen<ishmael.visayana.sameen@intel.com>
Plugin Details:
  Name                     mfx
  Description              MFX encoder/decoder/video post-processing plugins
  Filename                 C:\gst_MSDK_intel\gst-mfx-build_msvc\gst\mfx\gstmfx.dll
  Version                  2.0.2
  License                  LGPL
  Source module            gst_mfx
  Binary package           gst_mfx
  Origin URL               http://www.intel.com
GObject
 +----GInitiallyUnowned
       +----GstObject
             +----GstElement
                   +----GstVideoDecoder
                         +----GstMfxDec_h264
Pad Templates:
  SINK template: 'sink'
    Availability: Always
    Capabilities:
      video/x-h264
              alignment: au
                profile: { (string)constrained-baseline, (string)baseline, (string)main, (string)high }
          stream-format: byte-stream
  SRC template: 'src'
    Capabilities:
      video/x-raw(memory:MFXSurface)
                 format: { (string)NV12, (string)BGRA, (string)P010_10LE, (string)YUY2, (string)ENCODED }
                  width: [ 1, 2147483647 ]
                 height: [ 1, 2147483647 ]
              framerate: [ 0/1, 2147483647/1 ]
      video/x-raw(memory:GLMemory)
                 format: { (string)RGBA }
      video/x-raw
                 format: { (string)NV12, (string)BGRA, (string)P010_10LE, (string)YUY2 }
Here are sender and receiver pipelines:
1. H264 RTP ender pipeline on Nvidia TX2:
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw, format=UYVY, framerate=30/1' ! \
        nvvidconv ! 'video/x-raw(memory:NVMM),format=I420, framerate=30/1' ! \
        omxh264enc bitrate=$bitrate MeasureEncoderLatency=true ! 'video/x-h264, stream-format=(string)byte-stream' ! \
        rtph264pay ! udpsink host=$ip port=$port sync=false async=false
Using wireshark, I confirmed that the sps.pic_order_cnt_type is 2.
2. Receiver pipeline with avdec_h264:
gst-launch-1.0   udpsrc port=5000 caps="application/x-rtp, encoding-name=H264,payload=96" !  \
                       rtph264depay ! h264parse ! avh264_dec ! glimagesink sync=false async=false
3. Receiver pipeline with mfxh264dec:
gst-launch-1.0  --gst-plugin-load=C:\gst_MSDK_intel\gst-mfx-build_msvc\gst\mfx\gstmfx.dll udpsrc port=5000 caps="application/x-rtp, encoding-name=H264,payload=96" !  \
                       rtph264depay ! h264parse ! mfxh264dec live-mode=true ! glimagesink sync=false async=false
I found the latency topic was discussed:
https://software.intel.com/en-us/forums/intel-media-sdk/topic/704136
And in this discussion,  Dmitry E. (Intel) Thu, 06/22/2017 - 14:37 gave possible solutions.
Now here if 'live-mode=true',
In gst-libs/mfx/gstmfxdecoder.c, line 333~line 339:
 if (live_mode) {
    decoder->params.AsyncDepth = 1;
    decoder->bs.DataFlag = MFX_BITSTREAM_COMPLETE_FRAME;
    /* Hack for H264 low-latency streaming */
    if (decoder->params.mfx.CodecId == MFX_CODEC_AVC)
      decoder->params.mfx.DecodedOrder = 1;
And remember sender's sps.pic_order_cnt_type ==  2.
So ALL possible solutions have been applied,
but the latency is still there.
Any suggestion?
Dmitry_E_Intel
I believe the right sequence can be the following:
1) Please submit a bug against https://github.com/intel/gstreamer-media-SDK/
2) If 'mfxh264dec' maintainers confirm it's a MSDK issue, then the issue can be filled against https://github.com/Intel-Media-SDK/MediaSDK
Mark_L_Intel1
Hi Dou,
I noticed you are running decoding from RTSP stream behind GStreamer plugin, could you double check it with sample_decode.exe?
To do this, you have to input the raw stream from a file and then set up DepthAsync and DecodeOrder manually by following the example in https://software.intel.com/en-us/forums/intel-media-sdk/topic/704136
Mark
