sample_multi_transcode doesn't work MSS2017 for Linux, CentOS 7.3.1611
Timur_B_
I've installed MSS Professional Evaluation 2017 for Linux on clean CentOS 7.3.1611 powering by CPU Intel i7-6700k, but unfortunately sample_multi_transcode doesn't work. Also I run vainfo and sys_analyzer_linux.py diagnostic tool script, but both differ from expected results and contain some errors. I would appreciate your help and support.
Initially I've unpack SDK2017Production16.5.tar.gz, read getting started guide and made all prerequisite steps, then I run 'sudo ./install_sdk_CentOS.sh'. Unfortunately, setup was incomplete due to fact that my system already had installed newer versions of libdrm. Thus I edited shell script and added '--force' to rpm. This time I've got all stuff installed.
Here is my installation log:
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
 * base: mirror.digitalhusky.com
 * extras: mirror.digitalhusky.com
 * updates: mirror.yandex.ru
No packages in any requested group available to install or update
Package kernel-headers-3.10.0-514.6.1.el7.x86_64 already installed and latest version
Package kernel-devel-3.10.0-514.6.1.el7.x86_64 already installed and latest version
Package bc-1.06.95-13.el7.x86_64 already installed and latest version
Nothing to do
Package wget-1.14-13.el7.x86_64 already installed and latest version
Package bison-2.7-4.el7.x86_64 already installed and latest version
Package ncurses-devel-5.9-13.20130511.el7.x86_64 already installed and latest version
Package hmaccalc-0.9.13-4.el7.x86_64 already installed and latest version
Package zlib-devel-1.2.7-17.el7.x86_64 already installed and latest version
Package binutils-devel-2.25.1-22.base.el7.x86_64 already installed and latest version
Package elfutils-libelf-devel-0.166-2.el7.x86_64 already installed and latest version
Package rpm-build-4.11.3-21.el7.x86_64 already installed and latest version
Package redhat-rpm-config-9.1.0-72.el7.centos.noarch already installed and latest version
Package asciidoc-8.6.8-5.el7.noarch already installed and latest version
Package perl-ExtUtils-Embed-1.30-291.el7.noarch already installed and latest version
Package pesign-0.109-10.el7.x86_64 already installed and latest version
Package xmlto-0.0.25-7.el7.x86_64 already installed and latest version
Package audit-libs-devel-2.6.5-3.el7.x86_64 already installed and latest version
Package elfutils-devel-0.166-2.el7.x86_64 already installed and latest version
Package newt-devel-0.52.15-4.el7.x86_64 already installed and latest version
Package numactl-devel-2.0.9-6.el7_2.x86_64 already installed and latest version
Package pciutils-devel-3.5.1-1.el7.x86_64 already installed and latest version
Package python-devel-2.7.5-48.el7.x86_64 already installed and latest version
Package mesa-dri-drivers-11.2.2-2.20160614.el7.x86_64 already installed and latest version
Nothing to do
Preparing...                          ########################################
Updating / installing...
libdrm-2.4.66-55964.el7               ########################################
libva-1.67.0.pre1-55964.el7           ########################################
intel-linux-media-16.5-55964.el7      ########################################
Install finished. Please reboot.
intel-linux-media-devel-16.5-55964.el7########################################
libva-devel-1.67.0.pre1-55964.el7     ########################################
libva-utils-1.67.0.pre1-55964.el7     ########################################
libdrm-devel-2.4.66-55964.el7         ########################################
drm-utils-2.4.66-55964.el7            ########################################
intel-opencl-devel-16.5-55964         ########################################
intel-opencl-16.5-55964               ########################################
intel-i915-firmware-16.5-55964.el7    ########################################
Cleaning up / removing...
libdrm-devel-2.4.67-3.el7             ########################################
libdrm-2.4.67-3.el7                   ########################################
Removing previous version kmod-ukmd-16.5-55964.el7.x86_64...
Working. This may take some time ...
Done.
Installing kmod-ukmd-16.5-55964...
kmod-ukmd-16.5-55964.el7              ########################################
Done.
Installation done.
Maybe run: yum groups mark install (see man yum)
warning: intel-opencl-16.5-55964.x86_64.rpm: Header V3 RSA/SHA1 Signature, key ID 6da77827: NOKEY
Then I reboot it.
After reboot, I run 'lsmod | grep i915' and got following:
i915                 1307079  5
i2c_algo_bit           13413  1 i915
drm_kms_helper        146456  1 i915
drm                   372540  6 i915,drm_kms_helper
video                  24400  2 i915,asus_wmi
i2c_core               40756  6 drm,i915,i2c_i801,i2c_hid,drm_kms_helper,i2c_algo_bit
$lspci -k -s 00:02.0
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
    Subsystem: ASUSTeK Computer Inc. Device 8694
    Kernel driver in use: i915
    Kernel modules: i915
$vainfo
libva info: VA-API version 0.99.0
Xlib:  extension "XFree86-DRI" missing on display ":1".
libva info: va_getDriverName() returns -1
libva error: va_getDriverName() failed with unknown libva error,driver_name=(null)
vaInitialize failed with error code -1 (unknown libva error),exit
Which is different from listed in getting started guide.
Then I've read thread https://software.intel.com/en-us/forums/intel-media-sdk/topic/562172, downloaded diagnostic script and run it.
$sys_analyzer_linux.py
Hardware readiness checks:
 [ OK ] Processor name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
OS readiness checks:
 [ OK ] GPU visible to OS
Intel(R) Media Server Studio Install:
 [ OK ] user is root
 [ OK ] libva.so.1 found
 [ ERROR ] libva not loading Intel iHD
 [ ERROR ] vainfo not reporting codec entry points
 [ OK ] /dev/dri/renderD128 connects to Intel i915
Media SDK Plugins available:
(for more info see /opt/intel/mediasdk/plugins/plugins.cfg)
    H264LA Encoder     = 588f1185d47b42968dea377bb5d0dcb4
    VP8 Decoder     = f622394d8d87452f878c51f2fc9b4131
    HEVC Decoder     = 33a61c0b4c27454ca8d85dde757c6f8e
    HEVC Encoder     = 6fadc791a0c2eb479ab6dcd5ea9da347
Component Smoke Tests:
 [ OK ] Media SDK HW API level:1.19
 [ OK ] Media SDK SW API level:1.19
 [ OK ] OpenCL check:platform:Intel(R) OpenCL GPU OK CPU OK
I've no idea why libva.so doesn't load iHD_drv_video.so. I run it with strace, but there is tries to load iHD_drv_video.so at all.
When I run './sample_multi_transcode with -i::h264 test_stream.264 -o::h264 out.264 -hw', I got:
Multi Transcoding Sample Version 7.0.16053611
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Pipeline surfaces number (DecPool): 20
Return on error: error code -3,    /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/pipeline_transcode.cpp    2968
Return on error: error code -3,    /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/sample_multi_transcode.cpp    307
Here is my /var/log/Xorg.0.log:
[    17.061]
X.Org X Server 1.17.2
Release Date: 2015-06-16
[    17.061] X Protocol Version 11, Revision 0
[    17.061] Build Operating System:  2.6.32-573.18.1.el6.x86_64
[    17.061] Current Operating System: Linux localhost.localdomain 3.10.0-514.6.1.el7.x86_64 #1 SMP Wed Jan 18 13:06:36 UTC 2017 x86_64
[    17.061] Kernel command line: BOOT_IMAGE=/vmlinuz-3.10.0-514.6.1.el7.x86_64 root=/dev/mapper/cl-root ro rd.lvm.lv=cl/root rd.lvm.lv=cl/swap rhgb quiet LANG=en_US.UTF-8
[    17.061] Build Date: 06 November 2016  12:43:39AM
[    17.061] Build ID: xorg-x11-server 1.17.2-22.el7
[    17.061] Current version of pixman: 0.34.0
[    17.061]     Before reporting problems, check http://wiki.x.org
    to make sure that you have the latest version.
[    17.061] Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    17.061] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Feb 16 01:51:33 2017
[    17.061] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    17.061] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    17.061] (==) No Layout section.  Using the first Screen section.
[    17.061] (==) No screen section available. Using defaults.
[    17.061] (**) |-->Screen "Default Screen Section" (0)
[    17.061] (**) |   |-->Monitor "<default monitor>"
[    17.061] (==) No monitor specified for screen "Default Screen Section".
    Using a default monitor configuration.
[    17.061] (==) Automatically adding devices
[    17.061] (==) Automatically enabling devices
[    17.061] (==) Automatically adding GPU devices
[    17.061] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    17.061] (==) FontPath set to:
    catalogue:/etc/X11/fontpath.d,
    built-ins
[    17.061] (==) ModulePath set to "/usr/lib64/xorg/modules"
[    17.061] (II) The server relies on udev to provide the list of input devices.
    If no devices become available, reconfigure udev or disable AutoAddDevices.
[    17.061] (II) Loader magic: 0x7ffa7c43e020
[    17.061] (II) Module ABI versions:
[    17.061]     X.Org ANSI C Emulation: 0.4
[    17.061]     X.Org Video Driver: 19.0
[    17.061]     X.Org XInput driver : 21.0
[    17.061]     X.Org Server Extension : 9.0
[    17.062] (II) xfree86: Adding drm device (/dev/dri/card0)
[    17.063] (--) PCI:*(0:0:2:0) 8086:1912:1043:8694 rev 6, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[    17.063] (II) LoadModule: "glx"
[    17.081] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[    17.082] (II) Module glx: vendor="X.Org Foundation"
[    17.082]     compiled for 1.17.2, module version = 1.0.0
[    17.082]     ABI class: X.Org Server Extension, version 9.0
[    17.082] (==) AIGLX enabled
[    17.082] (==) Matched intel as autoconfigured driver 0
[    17.082] (==) Matched intel as autoconfigured driver 1
[    17.082] (==) Matched modesetting as autoconfigured driver 2
[    17.082] (==) Matched fbdev as autoconfigured driver 3
[    17.082] (==) Matched vesa as autoconfigured driver 4
[    17.082] (==) Assigned the driver to the xf86ConfigLayout
[    17.082] (II) LoadModule: "intel"
[    17.082] (II) Loading /usr/lib64/xorg/modules/drivers/intel_drv.so
[    17.132] (II) Module intel: vendor="X.Org Foundation"
[    17.132]     compiled for 1.17.2, module version = 2.99.917
[    17.132]     Module class: X.Org Video Driver
[    17.132]     ABI class: X.Org Video Driver, version 19.0
[    17.132] (II) LoadModule: "modesetting"
[    17.132] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[    17.132] (II) Module modesetting: vendor="X.Org Foundation"
[    17.132]     compiled for 1.17.2, module version = 1.17.2
[    17.132] (II) LoadModule: "fbdev"
[    17.132] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[    17.132] (II) Module fbdev: vendor="X.Org Foundation"
[    17.132]     compiled for 1.17.2, module version = 0.4.3
[    17.132] (II) LoadModule: "vesa"
[    17.132] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[    17.132] (II) Module vesa: vendor="X.Org Foundation"
[    17.132]     compiled for 1.17.2, module version = 2.3.2
[    17.132] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
    i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
    915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
    Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
    GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[    17.132] (II) intel: Driver for Intel(R) HD Graphics: 2000-6000
[    17.132] (II) intel: Driver for Intel(R) Iris(TM) Graphics: 5100, 6100
[    17.132] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics: 5200, 6200, P6300
[    17.132] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    17.133] (II) FBDEV: driver for framebuffer: fbdev
[    17.133] (II) VESA: driver for VESA chipsets: vesa
[    17.133] (++) using VT number 1
[    17.133] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20160229
[    17.133] (WW) Falling back to old probe method for modesetting
[    17.133] (WW) Falling back to old probe method for fbdev
[    17.133] (II) Loading sub module "fbdevhw"
[    17.133] (II) LoadModule: "fbdevhw"
[    17.199] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[    17.200] (II) Module fbdevhw: vendor="X.Org Foundation"
[    17.200]     compiled for 1.17.2, module version = 0.0.2
[    17.200]     ABI class: X.Org Video Driver, version 19.0
[    17.200] (WW) Falling back to old probe method for vesa
[    17.200] (--) intel(0): gen9 engineering sample
[    17.200] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[    17.200] (II) intel(0): Creating default Display subsection in Screen section
    "Default Screen Section" for depth/fbbpp 24/32
[    17.200] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[    17.200] (==) intel(0): RGB weight 888
[    17.200] (==) intel(0): Default visual is TrueColor
[    17.200] (II) intel(0): Output HDMI1 has no monitor section
[    17.200] (II) intel(0): Enabled output HDMI1
[    17.200] (II) intel(0): Output HDMI2 has no monitor section
[    17.200] (II) intel(0): Enabled output HDMI2
[    17.200] (II) intel(0): Output DP1 has no monitor section
[    17.201] (II) intel(0): Enabled output DP1
[    17.201] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[    17.201] (II) intel(0): Output VIRTUAL1 has no monitor section
[    17.201] (II) intel(0): Enabled output VIRTUAL1
[    17.201] (==) intel(0): TearFree disabled
[    17.201] (==) intel(0): DPI set to (96, 96)
[    17.201] (II) Loading sub module "dri2"
[    17.201] (II) LoadModule: "dri2"
[    17.201] (II) Module "dri2" already built-in
[    17.201] (II) Loading sub module "present"
[    17.201] (II) LoadModule: "present"
[    17.201] (II) Module "present" already built-in
[    17.201] (II) UnloadModule: "modesetting"
[    17.201] (II) Unloading modesetting
[    17.201] (II) UnloadModule: "fbdev"
[    17.201] (II) Unloading fbdev
[    17.201] (II) UnloadSubModule: "fbdevhw"
[    17.201] (II) Unloading fbdevhw
[    17.201] (II) UnloadModule: "vesa"
[    17.201] (II) Unloading vesa
[    17.201] (==) Depth 24 pixmap format is 32 bpp
[    17.201] (II) intel(0): SNA initialized with generic backend
[    17.201] (==) intel(0): Backing store enabled
[    17.201] (==) intel(0): Silken mouse enabled
[    17.201] (II) intel(0): HW Cursor enabled
[    17.201] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    17.201] (==) intel(0): DPMS enabled
[    17.201] (==) intel(0): Display hotplug detection enabled
[    17.201] (II) intel(0): Textured video not supported on this hardware or backend
[    17.201] (II) intel(0): [DRI2] Setup complete
[    17.201] (II) intel(0): [DRI2]   DRI driver: i965
[    17.201] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[    17.201] (II) intel(0): direct rendering: DRI2 enabled
[    17.201] (II) intel(0): hardware support for Present enabled
[    17.201] (--) RandR disabled
[    17.203] (II) SELinux: Disabled by boolean
[    17.208] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[    17.208] (II) AIGLX: enabled GLX_ARB_create_context
[    17.208] (II) AIGLX: enabled GLX_ARB_create_context_profile
[    17.208] (II) AIGLX: enabled GLX_EXT_create_context_es2_profile
[    17.208] (II) AIGLX: enabled GLX_INTEL_swap_event
[    17.208] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[    17.208] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[    17.208] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[    17.208] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[    17.208] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[    17.208] (II) AIGLX: Loaded and initialized i965
[    17.208] (II) GLX: Initialized DRI2 GL provider for screen 0
[    17.298] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    17.298] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    17.298] (**) Power Button: Applying InputClass "system-keyboard"
[    17.298] (II) LoadModule: "evdev"
[    17.298] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[    17.298] (II) Module evdev: vendor="X.Org Foundation"
[    17.298]     compiled for 1.17.2, module version = 2.9.2
[    17.298]     Module class: X.Org XInput Driver
[    17.298]     ABI class: X.Org XInput driver, version 21.0
[    17.298] (II) Using input driver 'evdev' for 'Power Button'
[    17.298] (**) Power Button: always reports core events
[    17.298] (**) evdev: Power Button: Device: "/dev/input/event2"
[    17.298] (--) evdev: Power Button: Vendor 0 Product 0x1
[    17.298] (--) evdev: Power Button: Found keys
[    17.298] (II) evdev: Power Button: Configuring as keyboard
[    17.298] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[    17.298] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    17.298] (**) Option "xkb_rules" "evdev"
[    17.298] (**) Option "xkb_layout" "us"
[    17.298] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    17.298] (**) evdev: Power Button: Device: "/dev/input/event1"
[    17.298] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input1/event1"
[    17.298] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    17.299] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[    17.299] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    17.299] (**) Sleep Button: Applying InputClass "system-keyboard"
[    17.299] (II) Using input driver 'evdev' for 'Sleep Button'
[    17.299] (**) Sleep Button: always reports core events
[    17.299] (**) evdev: Sleep Button: Device: "/dev/input/event0"
[    17.299] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[    17.299] (--) evdev: Sleep Button: Found keys
[    17.299] (II) evdev: Sleep Button: Configuring as keyboard
[    17.299] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input0/event0"
[    17.299] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[    17.299] (**) Option "xkb_rules" "evdev"
[    17.299] (**) Option "xkb_layout" "us"
[    17.299] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event9)
[    17.299] (II) No input driver specified, ignoring this device.
[    17.299] (II) This device may have been added with another device file.
[    17.299] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event10)
[    17.299] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event11)
[    17.299] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event12)
[    17.300] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event3)
[    17.300] (II) No input driver specified, ignoring this device.
[    17.300] (II) This device may have been added with another device file.
[    17.300] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event6)
[    17.300] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event7)
[    17.300] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event8)
[    17.300] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event5)
[    17.300] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    17.300] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[    17.300] (II) Using input driver 'evdev' for 'Eee PC WMI hotkeys'
[    17.300] (**) Eee PC WMI hotkeys: always reports core events
[    17.300] (**) evdev: Eee PC WMI hotkeys: Device: "/dev/input/event5"
[    17.300] (--) evdev: Eee PC WMI hotkeys: Vendor 0 Product 0
[    17.300] (--) evdev: Eee PC WMI hotkeys: Found keys
[    17.300] (II) evdev: Eee PC WMI hotkeys: Configuring as keyboard
[    17.300] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input5/event5"
[    17.300] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 9)
[    17.300] (**) Option "xkb_rules" "evdev"
[    17.300] (**) Option "xkb_layout" "us"
[    17.300] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[    17.307] AUDIT: Thu Feb 16 01:51:33 2017: 2185: client 1 connected from local host ( uid=0 gid=0 pid=2232 )
  Auth name: MIT-MAGIC-COOKIE-1 ID: 192
[    17.307] AUDIT: Thu Feb 16 01:51:33 2017: 2185: client 1 disconnected
[    17.308] AUDIT: Thu Feb 16 01:51:33 2017: 2185: client 1 connected from local host ( uid=0 gid=0 pid=2234 )
[    17.308] AUDIT: Thu Feb 16 01:51:33 2017: 2185: client 1 disconnected
[    17.310] AUDIT: Thu Feb 16 01:51:33 2017: 2185: client 1 connected from local host ( uid=0 gid=0 pid=947 )
[    18.101] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 2 connected from local host ( uid=42 gid=42 pid=2257 )
[    18.463] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 3 connected from local host ( uid=42 gid=42 pid=2278 )
[    18.463] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 3 disconnected
[    18.672] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 3 connected from local host ( uid=42 gid=42 pid=2287 )
[    18.672] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 3 disconnected
[    18.857] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 3 connected from local host ( uid=42 gid=42 pid=2287 )
[    18.858] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 3 disconnected
[    18.861] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 3 connected from local host ( uid=42 gid=42 pid=2278 )
[    18.865] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 4 connected from local host ( uid=42 gid=42 pid=2384 )
[    18.865] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 4 disconnected
[    18.867] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 4 connected from local host ( uid=42 gid=42 pid=2384 )
[    18.868] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 5 connected from local host ( uid=42 gid=42 pid=2384 )
[    18.873] AUDIT: Thu Feb 16 01:51:34 2017: 2185: client 6 connected from local host ( uid=42 gid=42 pid=2385 )
[    19.023] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 6 disconnected
[    19.026] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 3 disconnected
[    19.091] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 3 connected from local host ( uid=42 gid=42 pid=2408 )
[    19.091] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 3 disconnected
[    19.092] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 3 connected from local host ( uid=42 gid=42 pid=2408 )
[    19.172] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 6 connected from local host ( uid=42 gid=42 pid=2408 )
[    19.175] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 6 disconnected
[    19.456] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 6 connected from local host ( uid=42 gid=42 pid=2501 )
[    19.456] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 6 disconnected
[    19.457] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 6 connected from local host ( uid=42 gid=42 pid=2501 )
[    19.525] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 7 connected from local host ( uid=42 gid=42 pid=2501 )
[    19.563] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 8 connected from local host ( uid=42 gid=42 pid=2501 )
[    19.563] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 8 disconnected
[    19.646] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 8 connected from local host ( uid=42 gid=42 pid=2408 )
[    19.646] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 9 connected from local host ( uid=42 gid=42 pid=2501 )
[    19.647] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 8 disconnected
[    19.647] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 9 disconnected
[    19.802] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 8 connected from local host ( uid=42 gid=42 pid=2519 )
[    19.802] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 9 connected from local host ( uid=42 gid=42 pid=2518 )
[    19.803] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 8 disconnected
[    19.803] AUDIT: Thu Feb 16 01:51:35 2017: 2185: client 9 disconnected
[    21.805] AUDIT: Thu Feb 16 01:51:37 2017: 2185: client 8 connected from local host ( uid=42 gid=42 pid=2501 )
[    21.805] AUDIT: Thu Feb 16 01:51:37 2017: 2185: client 8 disconnected
[    21.838] AUDIT: Thu Feb 16 01:51:37 2017: 2185: client 8 connected from local host ( uid=42 gid=42 pid=2752 )
[    21.840] AUDIT: Thu Feb 16 01:51:37 2017: 2185: client 9 connected from local host ( uid=42 gid=42 pid=2752 )
[    21.840] AUDIT: Thu Feb 16 01:51:37 2017: 2185: client 9 disconnected
[    22.125] AUDIT: Thu Feb 16 01:51:38 2017: 2185: client 9 connected from local host ( uid=42 gid=42 pid=2812 )
[    22.578] AUDIT: Thu Feb 16 01:51:38 2017: 2185: client 10 connected from local host ( uid=42 gid=42 pid=2812 )
[    22.578] AUDIT: Thu Feb 16 01:51:38 2017: 2185: client 10 disconnected
[    24.063] AUDIT: Thu Feb 16 01:51:40 2017: 2185: client 10 connected from local host ( uid=42 gid=42 pid=2408 )
[    24.063] AUDIT: Thu Feb 16 01:51:40 2017: 2185: client 10 disconnected
Mark_L_Intel1
Hi Timur,
The script you used is only validated on CentOS 7.2.1511, this is why that was failed.
You have to use the generic approach described in the following page:
https://software.intel.com/en-us/articles/how-to-setup-media-server-studio-on-secondary-os-of-linux
The article only described the script in Ubuntu, you have to change to the CentOS command accordingly, for example, "apt-get"-->"yum", the other article shows the example of the command conversion:
https://software.intel.com/en-us/articles/mss-centos-install-options
Hope this helps.
Mark.
Timur_B_
Hi Mark,
I've re-installed CentOS 7.2.1511. Now your sample works fine. So, my problem is solved. Thank you!
What happen if after successful installation of MSS, my CentOS will be automatically upgraded to newer minor version. Should I re-install MSS again? Or minor release upgrade will not affect the operation of Intel HW codecs?
