We have struggled with this for the better part of today to try to get ffmpeg encoding h264 video with qsv.
We have tried using the static builds from http://johnvansickle.com/ffmpeg/ (ffmpeg 3.1 as well as a nightly git snapshot), and we have built our own static build (2.8.7). Both of them segfault as soon as we try to output with h264_qsv.
The only real behavioral difference among the various builds is that -hwaccels on our build shows no available hardware acceleration methods. The johnvansickle.com build shows "qsv" and "vaapi" as available methods. I suspect that build has a better chance of working because it sees the hardware acceleration methods.
None of the builds output any "libva info" lines (as shown in the Intel QuickSync Video and ffmpeg PDF). They show the input stream data, and then immediately segfault.
We have followed the documentation in "Intel QuickSync Video and ffmpeg" and "Intel® Media Server Studio 2016 - Driver, SDK, Samples for Linux" to the letter. We are using CentOS 7.1. We have a Broadwell processor.
What are we missing?
Here is the output of sys_analyzer_linux.py:
-------------------------- Hardware readiness checks: -------------------------- [ OK ] Processor name: Intel(R) Core(TM) i7-5775C CPU @ 3.30GHz -------------------------- OS readiness checks: -------------------------- [ OK ] GPU visible to OS [ OK ] Linux distro suitable for Media Server Studio 2016 Gold -------------------------- Media Server Studio Install: -------------------------- [ OK ] user in video group [ OK ] libva.so.1 found [ OK ] vainfo reports valid codec entry points [ OK ] /dev/dri/renderD128 connects to Intel i915 -------------------------- Component Smoke Tests: -------------------------- [ OK ] Media SDK HW API level:1.17 [ OK ] Media SDK SW API level:1.17 [ OK ] OpenCL check:platform:Intel(R) OpenCL GPU OK CPU OK -------------------------- Media SDK Plugins available: (for more info see /opt/intel/mediasdk/plugins/plugins.cfg) -------------------------- H264LA Encoder = 588f1185d47b42968dea377bb5d0dcb4 VP8 Decoder = f622394d8d87452f878c51f2fc9b4131
Here is the output of vainfo:
$ ./vainfo libva info: VA-API version 0.99.0 libva info: va_getDriverName() returns 0 libva info: User requested driver 'iHD' libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so libva info: Found init function __vaDriverInit_0_32 libva info: va_openDriver() returns 0 vainfo: VA-API version: 0.99 (libva 1.67.0.pre1) vainfo: Driver version: 16.4.4.47109-ubit vainfo: Supported profile and entrypoints VAProfileH264Baseline : VAEntrypointEncSlice VAProfileH264Baseline : <unknown entrypoint> VAProfileH264Baseline : <unknown entrypoint> VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: <unknown entrypoint> VAProfileH264ConstrainedBaseline: <unknown entrypoint> VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264Main : <unknown entrypoint> VAProfileH264Main : <unknown entrypoint> VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264High : <unknown entrypoint> VAProfileH264High : <unknown entrypoint> VAProfileMPEG2Simple : VAEntrypointEncSlice VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointEncSlice VAProfileMPEG2Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileVP8Version0_3 : <unknown entrypoint> VAProfileHEVCMain : VAEntrypointEncSlice VAProfileVP9Profile0 : VAEntrypointEncSlice VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile0 : <unknown entrypoint> <unknown profile> : VAEntrypointVideoProc VAProfileNone : VAEntrypointVideoProc VAProfileNone : <unknown entrypoint>
Hi Jason,
From the logs you have provided I don't see an issue in using quick sync.
Your configuration- i7-5775C is supported, Cent OS is the gold OS distribution.
Please run this test and confirm the result - Go to package -> samples bin -> Run any pre-compiled sample.
For e.g.
./sample_multi_transcode -i::h264 content/test_stream.264 -o::h264 out.264 -hw
Multi Transcoding Sample Version 6.0.16043361.361
Pipeline surfaces number: 42
MFX HARDWARE Session 0 API ver 1.17 parameters:
Input video: AVC
Output video: AVC
Session 0 was NOT joined with other sessions
Transcoding started
Transcoding finished
Common transcoding time is 0.10 sec
MFX session 0 transcoding PASSED:
Processing time: 0.10 sec
Number of processed frames: 101
If you are successfully able to run the sample then your installation is correct. Next step is to follow the instruction from this ffmpeg paper - http://www.intel.com/content/dam/www/public/us/en/documents/white-papers/quicksync-video-ffmpeg-install-valid.pdf .
Let us know if you still see any issue.
Surbhi
I forgot to mention we ran that test yesterday, and it was successful. However, I tried to use the sample_multi_transcode to transcode another h264 file from our system (a much larger file), and it did not work.
Sorry I don't have the exact output; we are in the process of rebuilding that system now. We are going to start over to make sure we've followed all the steps to the letter. Yesterday, we used a minimal CentOS 7.1 installer. Today, we will try with the full DVD and we will select "Development and Creative Workstation" when we install.
I will report back.
We rebuilt the system from scratch, and we still can't use h264_qsa encoding with ffmpeg. I'm confident that we are following the instructions provided in the PDF documentation).
Here is exactly what we did:
Install CentOS 7.1 "Development and Creative Workstation"
Add our user ("www") to the "video" group:
sudo usermod -a -G video www
Unpack the MediaServerStudio tarball and install the software. As root:
# ./install_sdk_UMD_CentOS.sh # mkdir /MSS # chown www.www /MSS
As user www:
$ cp build_kernel_rpm_CentOS.sh /MSS $ cd /MSS $ ./build_kernel_rpm*.sh
As root:
# cd /MSS/rpmbuild/RPMS/x86_64 # rpm --force -Uvh kernel-3.10.*.rpm
As root, remove "nomodeset" from /etc/grub2.conf. (This isn't really documented anywhere, except for in scattered forum posts. If nomodeset is passed as a kernel parameter, the /dev/dri directory does not get created, and nothing works.)
Reboot the system.
Run the system analyzer; everything seems to be in order.
$ ./sys_analyzer_linux.py -------------------------- Hardware readiness checks: -------------------------- [ OK ] Processor name: Intel(R) Core(TM) i7-5775C CPU @ 3.30GHz -------------------------- OS readiness checks: -------------------------- [ OK ] GPU visible to OS [ OK ] Linux distro suitable for Media Server Studio 2016 Gold -------------------------- Media Server Studio Install: -------------------------- [ OK ] user in video group [ OK ] libva.so.1 found [ OK ] vainfo reports valid codec entry points [ OK ] /dev/dri/renderD128 connects to Intel i915 -------------------------- Component Smoke Tests: -------------------------- [ OK ] Media SDK HW API level:1.17 [ OK ] Media SDK SW API level:1.17 [ OK ] OpenCL check:platform:Intel(R) OpenCL GPU OK CPU OK -------------------------- Media SDK Plugins available: (for more info see /opt/intel/mediasdk/plugins/plugins.cfg) -------------------------- H264LA Encoder = 588f1185d47b42968dea377bb5d0dcb4 VP8 Decoder = f622394d8d87452f878c51f2fc9b4131
Now run test transcodes. The transcode works with one of the supplied content files, but not with one of our own files.
$ ./sample_multi_transcode -i::h264 content/test_stream.264 -o::h264 out.264 -hw Multi Transcoding Sample Version 6.0.16043361.361 libva info: VA-API version 0.99.0 libva info: va_getDriverName() returns 0 libva info: User requested driver 'iHD' libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so libva info: Found init function __vaDriverInit_0_32 libva info: va_openDriver() returns 0 Pipeline surfaces number: 42 MFX HARDWARE Session 0 API ver 1.17 parameters: Input video: AVC Output video: AVC Session 0 was NOT joined with other sessions Transcoding started Transcoding finished Common transcoding time is 0.07 sec MFX session 0 transcoding PASSED: Processing time: 0.07 sec Number of processed frames: 101 The test PASSED
Now try the same sample transcoder using one of our own MP4 files (h264 (Baseline) (avc1 / 0x31637661), yuv420p(tv, bt709), 960x540 [SAR 1:1 DAR 16:9], 2188 kb/s, 29.97 fps). It errors out. This may or may not be related to the problems we're having with ffmpeg.
$ ./sample_multi_transcode -i::h264 /tmp/246897-fish.mp4 -o::h264 out.264 -hw Multi Transcoding Sample Version 6.0.16043361.361 libva info: VA-API version 0.99.0 libva info: va_getDriverName() returns 0 libva info: User requested driver 'iHD' libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so libva info: Found init function __vaDriverInit_0_32 libva info: va_openDriver() returns 0 Return on error: error code -10, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK1/git/mdp_msdk-samples/samples/sample_multi_transcode/src/sample_multi_transcode.cpp 273
Now we prepare to build ffmpeg.
Copy the headers into place:
# mkdir /opt/intel/mediasdk/include/mfx # cp /opt/intel/mediasdk/include/*.h /opt/intel/mediasdk/include/mfx
Create a libmfx.pc file and put it into the directory specified by the PKG_CONFIG_PATH for the build:
prefix=/opt/intel/mediasdk exec_prefix=${prefix} libdir=${prefix}/lib/lin_x64 includedir=${prefix}/include Name: libmfx Description: Intel Media Server Studio SDK Version: 16.4.2 Libs: -L${libdir} -lmfx -lva -lstdc++ -ldl -lva-drm -ldrm Cflags: -I${includedir} -I/usr/include/libdrm
We are building a static ffmpeg, so we need to install static versions of glibc and libstdc++. I wonder if this could be part of the problem, since this updates the glibc package before it installs glibc-static. Maybe the Intel-distributed binary code was linked against one version of glibc, and now we're introducing another version of glibc?
# yum install glibc-static # yum install libstdc++-static
We use a modified version of the build system at https://github.com/zimbatm/ffmpeg-static. We add in static builds of libva, libpciaccess, libpthread-stubs, and drm.
Once ffmpeg is built, we test it. Unfortunately, it sees no available hardware acceleration methods:
$ ./ffmpeg -hwaccels ffmpeg version 2.8.7-static Copyright (c) 2000-2016 the FFmpeg developers built with gcc 4.8.5 (GCC) 20150623 (Red Hat 4.8.5-4) configuration: --prefix=/home/www/ffmpeg/2.8.7/ffmpeg-static-master/target --extra-cflags='-I/home/www/ffmpeg/2.8.7/ffmpeg-static-master/target/include -Bstatic' --extra-ldflags='-ldl -L/home/www/ffmpeg/2.8.7/ffmpeg-static-master/target/lib -lm -static' --extra-version=static --disable-debug --disable-shared --enable-static --extra-cflags=--static --disable-ffplay --disable-ffserver --disable-doc --enable-gpl --enable-pthreads --enable-postproc --enable-gray --enable-runtime-cpudetect --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-bzlib --enable-zlib --enable-nonfree --enable-version3 --enable-libvpx --disable-devices --enable-libmfx libavutil 54. 31.100 / 54. 31.100 libavcodec 56. 60.100 / 56. 60.100 libavformat 56. 40.101 / 56. 40.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 40.101 / 5. 40.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 2.101 / 1. 2.101 libpostproc 53. 3.100 / 53. 3.100 Hardware acceleration methods:
And then trying a transcode, it segfaults:
$ ./ffmpeg -i /tmp/246897-fish.mp4 -c:v h264_qsv /tmp/qsv.mp4 ffmpeg version 2.8.7-static Copyright (c) 2000-2016 the FFmpeg developers built with gcc 4.8.5 (GCC) 20150623 (Red Hat 4.8.5-4) configuration: --prefix=/home/www/ffmpeg/2.8.7/ffmpeg-static-master/target --extra-cflags='-I/home/www/ffmpeg/2.8.7/ffmpeg-static-master/target/include -Bstatic' --extra-ldflags='-ldl -L/home/www/ffmpeg/2.8.7/ffmpeg-static-master/target/lib -lm -static' --extra-version=static --disable-debug --disable-shared --enable-static --extra-cflags=--static --disable-ffplay --disable-ffserver --disable-doc --enable-gpl --enable-pthreads --enable-postproc --enable-gray --enable-runtime-cpudetect --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-bzlib --enable-zlib --enable-nonfree --enable-version3 --enable-libvpx --disable-devices --enable-libmfx libavutil 54. 31.100 / 54. 31.100 libavcodec 56. 60.100 / 56. 60.100 libavformat 56. 40.101 / 56. 40.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 40.101 / 5. 40.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 2.101 / 1. 2.101 libpostproc 53. 3.100 / 53. 3.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/tmp/246897-fish.mp4': Metadata: major_brand : mp42 minor_version : 0 compatible_brands: mp42isom Duration: 00:01:50.94, start: 0.000000, bitrate: 2292 kb/s Stream #0:0(eng): Video: h264 (Baseline) (avc1 / 0x31637661), yuv420p(tv, bt709), 960x540 [SAR 1:1 DAR 16:9], 2188 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc (default) Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 98 kb/s (default) Segmentation fault (core dumped)
I've tried with the static builds available at http://johnvansickle.com/ffmpeg/ as well. Note that in order to use these, I had to configure the dynamic linker so it can find libmfx:
# echo /opt/intel/mediasdk/lib64 > /etc/ld.so.conf.d/intel-mfx.conf # ldconfig # ldconfig -p | grep mfx libmfxsw64.so (libc6,x86-64) => /opt/intel/mediasdk/lib64/libmfxsw64.so libmfxhw64.so (libc6,x86-64) => /opt/intel/mediasdk/lib64/libmfxhw64.so
These builds are able to see hwaccels:
$ ./ffmpeg -hwaccels ffmpeg version 3.1-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.4.0 (Debian 5.4.0-4) 20160609 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --enable-libzimg --cc=gcc libavutil 55. 27.100 / 55. 27.100 libavcodec 57. 48.101 / 57. 48.101 libavformat 57. 40.101 / 57. 40.101 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 46.102 / 6. 46.102 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 1.100 / 2. 1.100 libpostproc 54. 0.100 / 54. 0.100 Hardware acceleration methods: qsv vaapi
but they still segfault:
$ ./ffmpeg -i /tmp/246897-fish.mp4 -c:v h264_qsv /tmp/qsv.mp4 ffmpeg version 3.1-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.4.0 (Debian 5.4.0-4) 20160609 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --enable-libzimg --cc=gcc libavutil 55. 27.100 / 55. 27.100 libavcodec 57. 48.101 / 57. 48.101 libavformat 57. 40.101 / 57. 40.101 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 46.102 / 6. 46.102 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 1.100 / 2. 1.100 libpostproc 54. 0.100 / 54. 0.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/tmp/246897-fish.mp4': Metadata: major_brand : mp42 minor_version : 0 compatible_brands: mp42isom Duration: 00:01:50.94, start: 0.000000, bitrate: 2292 kb/s Stream #0:0(eng): Video: h264 (Baseline) (avc1 / 0x31637661), yuv420p(tv, bt709), 960x540 [SAR 1:1 DAR 16:9], 2188 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc (default) Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 98 kb/s (default) Segmentation fault (core dumped)
OK -- I tried to compile just using
./configure --enable-libmfx --enable-nonfree
without all my other config flags and static libraries.
Looks like this build worked! So I guess there's something wrong with my static builds, as well as the ones that John provides online.
Hi Jason,
I am glad build got working for you, its a great information for others to refer. Appreciate you documenting all the steps here. One thing I noticed above which I wanted to clarify that our samples take elementary streams input and provide elementary stream output due to which sample_multi_transcode failed with your input i.e. mp4. If you could demux the content and passed it from the sample it should work for the future reference.
Have a fun time coding with qsv!
Surbhi
i am using this edition
pwd
/home/htxk/Downloads/MediaServerStudioEssentials2017/SDK2017Production16.5/CentOS
./cat /proc/cpuinfo
processor : 1
vendor_id : GenuineIntel
cpu family : 6
model : 94
model name : Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
stepping : 3
microcode : 0x8a
cpu MHz : 800.000
cache size : 6144 KB
physical id : 0
siblings : 4
core id : 1
cpu cores : 4
after installing:
uname -r
3.10.0-327.el7.x86_64
cat /etc/redhat-release
CentOS Linux release 7.2.1511 (Core)
ls /opt/intel/mediasdk/lib64/
iHD_drv_video.so libmfxhw64.so libmfxsw64.so
libmfxhw64-p.so.1.19 libmfxsw64-p.so.1.19
env |grep 'LIBVA'
LIBVA_DRIVERS_PATH=/opt/intel/mediasdk/lib64
LIBVA_DRIVER_NAME=iHD
vainfo
error: can't connect to X server!
vainfo: Driver version: 16.5.55964-ubit
VAProfileHEVCMain : VAEntrypointVLD
lsmod |grep 'i915'
i915 1321453 4
i2c_algo_bit 13413 1 i915
drm_ukmd_kms_helper 141060 1 i915
drm_ukmd 369649 3 i915,drm_ukmd_kms_helper
drm_ukmd_compat 109279 1 i915
video 24400 1 i915
i2c_core 40582 7 drm,i915,i2c_i801,i2c_hid,i2c_algo_bit,drm_ukmd,drm_ukmd_kms_helper
ls -l /dev/dri/
total 0
crw-rw----+ 1 root video 226, 0 Jan 16 01:21 card0
crw-------. 1 root video 226, 64 Jan 16 01:21 controlD64
crw-rw----+ 1 root video 226, 128 Jan 16 01:21 renderD128
groups
htxk video
my trouble is that, when running ffmpeg to transode, it show segmentation fault just as the Jason P described.
i need you help.
best regards.
![](/skins/images/DC0E2679F7049B943291D1ED082A478E/responsive_peak/images/icon_anonymous_message.png)
