Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Arc showstopper: broken interlaced encoding
r00tb33r
Interlaced encoding is broken on Arc.  That's a showstopper for encoding interlaced broadcast content for TV stations (1080i HD content for 1080i TV stations).
For reference the same interlaced encoding operation works on DG1, but does not work on Arc (DG2).
This regression happened before and was later fixed by Intel.  Need to do this again.
https://community.intel.com/t5/Media-Intel-oneAPI-Video/Potential-Skylake-HEVC-encoding-showstopper-Interlaced-content/td-p/1067972
Example:
ffmpeg -loglevel error -hwaccel qsv -codec:v h264_qsv -i in1.ts -codec:v h264_qsv -flags +ilme+ildct -top 1 -r:v 30000/1001 -y output_int.mp4
[h264_qsv @ 0000014bdf934880] Current picture structure is unsupported
[h264_qsv @ 0000014bdf934880] some encoding parameters are not supported by the QSV runtime. Please double check the input parameters.
Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
Specifically, the "+ildct" option no longer works, and the transcode output is progressive (de-interlaced), however should be interlaced (verified to work correctly on DG1 and UHD 630).
This appears to be a (media?) driver regression.
We are evaluating Arc products including Flex 140 and Arc Pro for broadcast production use, and this is a showstopper for us, we can't use this like this.  Please fix this ASAP.
RemyaP_Intel
We are working on this internally. We will get back to you soon with an update
Remya Premdas
RemyaP_Intel
We regret to inform you that, currently there is no support to Encode Interlaced video to h.264(AVC) on DG2 and this might be planned to feature in the long term. Could you please let us know if you need any further information on this.
Remya Premdas
r00tb33r
Yes, I'd like to know if interlacing is a planned feature in a future update.
RemyaP_Intel
Appreciate your interest. As mentioned earlier currently, we don't have an ETA for this feature on DG2s. Your request will be kept on record in our database. We will continue to review this request and all other feature requests each year during planning for the next major release of the product. Your feedback and suggestions are important to us. Thank you for sending us this request to improve our product.
Could you please confirm whether we can go ahead and close this thread?
Remya Premdas
RemyaP_Intel
We haven't received any response from your end. Can we go ahead and close this thread?
Remya Premdas
RemyaP_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
