Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Encode yuv frames
Viktor_S_
I want encode yuv frames from camera to h264.
Where in pipeline_encode i should fix it?
May be you have example?
Best regards Viktor.
Jiandong_Z_Intel
Hi Viktor,
Can you provide more details regarding this issue ?
1. Which OS are you using ? Linux or Windows ?
2. What is Driver and MSDK version ?
3. What is MSDK samples version ?
4. What is special YUV format output by your camera ? NV12 ?
Zachary
Viktor_S_
Here is my system:
Linux Samples 6.0.160431175.175 sample_encode with pipeline model.
MediaServerStudio Essentials 2015 R6
CentOS 7 kernel 229.
Intel® 4th generation Core™ i7-4770R
Intel® Iris™ Pro graphics 5200
I grab RGB frames from camera to the IPP function. So i can convert them to NV12, but may be it is possible pass 8UC3R ipp image to the MSDK surface?
Please help me.
Jiandong_Z_Intel
Hi Viktor,
First we can found NV12 is supported as "SDK function input"  in Table 8 in page 26 in Intel Media SDK
So MSDK encode need NV12 as input. I think you need convert frames to NV12.
How to find a good way to do the conversion ? I don't know what do you think of ?
Can you explain some details regarding 8UC3R ? It looks like 8UC3R is not supported by MSDK.
Zachary
Viktor_S_
Thank you.
I will convert RGB to YUV NV12 with ipp function.
But how i can insert yuv binary frame (buffer) into the encoder->run() chain?
Can you explain?
Jeffrey_M_Intel1
Hi Viktor,
You can convert RGBA to NV12 with VPP.
Alternately, you can use IPP to convert RGB24 to NV12 like this:
        // read RGB data
         for (int i = 0; i < inputHeight; i++) {
            nBytesRead = (mfxU32)fread(pRGB + i * stridesrcRGB, 3, inputWidth, fSource);
        // convert RGB24 to NV12
        ippiRGBToYCbCr420_8u_C3P2R(
            pRGB,stridesrcRGB,
            pEncSurfaces[nEncSurfIdx]->Data.Y, pEncSurfaces[nEncSurfIdx]->Data.Pitch,
            pEncSurfaces[nEncSurfIdx]->Data.UV,pEncSurfaces[nEncSurfIdx]->Data.Pitch,
            srcsizeY);
        for (;;) {
            // Encode a frame asychronously (returns immediately)
            sts = mfxENC.EncodeFrameAsync(NULL, pEncSurfaces[nEncSurfIdx], &mfxBS, &syncp);
           //... (check normal state machine cases here
Viktor_S_
Thank you very much!
Jiandong_Z_Intel
Hi Viktor,
It looks like you have got your answer. I am closing the thread, please do a new post if you have other questions.
Zachary
