Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3084 Discussions
Error in sample example with the use of "-rdynamic" option in gcc.
sumit_j_1
I was trying out sample example with following setting in gcc.
g++ -ggdb -rdynamic  -o $(EXEC) $(SRCS) $(CFLAGS) $(LFLAGS)
With this change, code gets stuck.
GDB summary,
(gdb) bt
#0  0x00007ffff59a5c10 in MFXInit () from /opt/intel/mediasdk/lib64/libmfxhw64-p.so.1.15
#1  0x00000000004152df in MFX_DISP_HANDLE::LoadSelectedDLL(char const*, eMfxImplType, int, int, mfxInitParam&) ()
#2  0x00000000004129a5 in MFXInitEx ()
#3  0x0000000000413a7b in MFXInit ()
#4  0x000000000040c90e in MFXVideoSession::Init (this=0x7fffffffe250, impl=3, ver=0x7fffffffe200) at /opt/intel/mediasdk//include/mfxvideo++.h:45
#5  0x000000000040d891 in Initialize (impl=3, ver=..., pSession=0x7fffffffe250, pmfxAllocator=0x0, bCreateSharedHandles=false)
    at ../common/common_utils_linux.cpp:28
#6  0x000000000040c6ff in main (argc=1, argv=0x7fffffffe5b8) at src/simple_session.cpp:47
Why after MFX_DISP_HANDLE, MFXInit() calls is made again.
WIthout "rdynamic"  code is working fine.
Sumit Jha
Bjoern_B_Intel
Hi Sumit,
I am investigating as I can reproduce it on my system as well.
Please give me a few days to come back to you.
Bjoern
Bjoern_B_Intel
Hi Sumit,
MFXInit() function name (and symbol) is used in dispatcher libmfx.a as well as in dynamic libmfxhw64-p.so. This leads to a naming conflict during runtime when using rdynamic compiler flag. The two MFXInit functions you are seeing actually belong to different libraries.
I escalated the issue to our SDK engineering team, asking for a solution/fix.
Thanks for bringing this issue up.
Best,
Bjoern
Greg_H_1
Is there a status update for this issue?  It seems to still occur with the 2017 version.  -rdynamic is useful to make backtrace_symbols() work correctly.
