Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
How to use Media SDK with V4l Linux ?
rshal2
New Contributor II
I've  been evaluating media sdk , but haven't yet understand how it should be used with capture device.
It seems that all examples for media sdk server (linux) refer to encode/decode only, but we are interested to work with video capture:
capture->encode->file
Is there any hint/tip as to how it should be used with capture device output ? Should it be used with v4l ?
Ran
Jiandong_Z_Intel
Hi Ran,
My answer is No, But It looks like you should wait some experts to answer the question.
Zachary
Jiandong_Z_Intel
Hi Ran,
I think v4l is good on Linux to do the capture and following thing need to do -
1. make sure your camera is connect to computer correctly.
2. make sure the driver for camera is ready and load successful in kernel.
3. open camera device and call ioctl functions to fetch the frame.
Do you agree ?
Zachary
rshal2
New Contributor II
Hi Zachary,
I apologyze for the English. I think the question was not well clear enough.
I am interested to know if there is any sample which shows how media sdk take frames from a v4l2 device.
I only found samples which shows this pipeline:
raw video file -> media sdk encode -> file  (and opposite direction for decode)
But not yet something like this:
v4l capture device -> media sdk encode -> file
If there is any such simple example, it can help me a lot.
Ran
rshal2
New Contributor II
Are there any samples which demonstrate how to use v4l device ?
Ran
Jiandong_Z_Intel
Hi Ran,
Zachary
Satish_P_
Hello
I have also Similar Problem , we are using V4L2 based SDI input device , and working to test some encoder based media sdk but we couldn't find a way to capture data from V4l2 device .
please help to overcome obstacle faced for Media SDK use
Satish Pandey
