3030 Discussions
MFXInit(MFX_IMPL_HARDWARE,{0,1},&session) fails,returning -3.
sam_p_
On a i7-4700eq running centos 7, I installed the rpms from "MediaSeverStudioEssentials2015R3.tar.gz" and the kernel modules, and whenever I try to run MFXInit i get -3.
dmesg is spitting out "[drm:i915_set_reset_status] *ERROR* render ring hung inside bo (0x1885000 ctx 1) at 0x1885274"
I did get the kernel source from http://vault.centos.org/7.0.1406/updates/Source/SPackages/kernel-3.10.0-123.9.3.el7.src.rpm and am running it.
Shaojuan_Z_Intel
Did you run it as root?
sam_p_
It dosn't work running as root or running as a normal user.
Sravanthi_K_Intel
Hi Sam,
Can you ensure if you have the right kernel loaded and you have loaded the correct drm module? Please send us the output of the following commands:
- uname -ar
- lspci -nn | grep VGA
- lsmod | grep i915
sam_p_
accidental duplicate post
sam_p_
sam_p_
uname -ar
Linux stalker-swtb-2b-lx.aero.ball.com 3.10.0-123.9.3.29404.MSSr1.el7.x86_64 #1 SMP Wed Apr 22 20:26:12 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
00:02.0 VGA compatible controller [0300]: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller [8086:0416] (rev 06)
lsmod | grep i915
i915                  734314  5
drm_kms_helper         52758  1 i915
drm                   297577  4 i915,drm_kms_helper
i2c_algo_bit           13413  2 igb,i915
i2c_core               40325  6 drm,igb,i915,i2c_i801,drm_kms_helper,i2c_algo_bit
video                  19267  1 i915
sam_p_
uname -ar
lsmod | grep i915
i915                  734314  5
video                  19267  1 i915
Sravanthi_K_Intel
Based on this information, looks like your installation was successful.
Can you let us know what sample you are running, the command line being used and snapshot of the output? Also, please run the sample application as root (not sudo, but as root).
Also, can you give more system details: processor and graphics for example.
sam_p_
It appears as though even though rpm said it had installed libva, it had not, i apologise for wasting your time but it is working.
Sravanthi_K_Intel
Thanks for getting back to us Sam. Glad it worked. Happy coding!
