Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
libva intel-driver source
Will_K_
Can someone point me to the source for the MediaSDK changes to the libva intel driver?
The 2015R6 release only contains source for libva and libdrm, not the libva intel-driver package.
will
Sravanthi_K_Intel
Hi Will, Are you asking for source for iHD_drv_video.so driver? In general, we do not share the driver source code externally (iHD is closed source). If I misunderstood, can you be more specific? Thanks.
Will_K_
Perhaps I misunderstood.  I thought that iHD_drv_video.so was some version of http://cgit.freedesktop.org/vaapi/intel-driver.  Are you saying that it is actually a closed-source alternative?
thanks,
will
Sravanthi_K_Intel
Hi Will - The repo you are pointing to is the opensource stack, while iHD is the closed source module that is packaged with media server studio and is required for the media sdk. So yes, these two are different. Hope this clarifies your question.
if you can let us know what you are looking to do, we can point you in the right direction may be. Can you explain your application and media pipeline that requires source access?
