Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
something was wrong with vpp use
china_y_
i want to use vpp for color format convert
everything was ok at the beginning
i follow the step in vpp demo
but when i get here
it always return -15
i check it  it means invalid video parameters
follow is my set
pParam->vpp.In.FourCC = MFX_FOURCC_YV12 ;
pParam->vpp.In.CropX  = 0 ;
 pParam->vpp.In.CropY  = 0 ;
 pParam->vpp.In.CropW =  m_BitInfoHeader.biWidth ;
 pParam->vpp.In.CropH =  m_BitInfoHeader.biHeight ;
  pParam->vpp.In.FrameRateExtD = 1 ;
    pParam->vpp.In.FrameRateExtN = 30  ;
    pParam->vpp.In.Width = MSDK_ALIGN16(m_BitInfoHeader.biWidth) ;
    pParam->vpp.In.Height =MSDK_ALIGN16(m_BitInfoHeader.biHeight) ;
    pParam->vpp.In.PicStruct = MFX_PICSTRUCT_PROGRESSIVE ;
    //  out put data
    pParam->vpp.Out.FourCC = MFX_FOURCC_YV12 ;
    pParam->vpp.Out.CropX = 0 ;
    pParam->vpp.Out.CropY = 0 ;
    pParam->vpp.Out.CropW = m_nDstWidth ;
    pParam->vpp.Out.CropH = m_nDstHeight ;
    pParam->vpp.Out.PicStruct = MFX_PICSTRUCT_PROGRESSIVE ;
    pParam->vpp.Out.FrameRateExtN = 30 ;
    pParam->vpp.Out.FrameRateExtD = 1 ;
    pParam->IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY | MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
    pParam->NumExtParam = 0 ;
    pParam->ExtParam = NULL ;
sts = m_pMfxVideoVPP->QueryIOSurf(pParamm,request) ;
this always return -15
did i miss some thing  in my setting ?
thank you advance
Petter_L_Intel
Hi China,
VPP output format : MFX_FOURCC_YV12   is not supported!   If you want to convert from YV12 for NV12 then the input type should be MFX_FOURCC_YV12  and output MFX_FOURCC_NV12
Also, the FrameRateExtD/N values are invered at in and output. Probably not what you want, and may cause issues.
Petter
china_y_
Petter Larsson (Intel) wrote:
Hi China,
Petter
thank you very much for your answer
best  wishes
china_y_
MFXInit.impl=HARDWARE|VIA_D3D9
MFXInit.ver=1.1
MFXInit.status=MFX_ERR_NONE
vpp.QueryIOSurf.par.AsyncDepth=0
vpp.QueryIOSurf.par.vpp.In.FourCC=YV12
vpp.QueryIOSurf.par.vpp.In.Resolution=(320,240)
vpp.QueryIOSurf.par.vpp.In.Crop=(0,0,320,240)
vpp.QueryIOSurf.par.vpp.In.FrameRate=15/1
vpp.QueryIOSurf.par.vpp.In.AspectRatio=0:0
vpp.QueryIOSurf.par.vpp.In.PicStruct=PROGRESSIVE
vpp.QueryIOSurf.par.vpp.In.ChromaFormat=MONO
vpp.QueryIOSurf.par.vpp.Out.FourCC=NV12
vpp.QueryIOSurf.par.vpp.Out.Resolution=(0,0)
vpp.QueryIOSurf.par.vpp.Out.Crop=(0,0,320,240)
vpp.QueryIOSurf.par.vpp.Out.FrameRate=15/1
vpp.QueryIOSurf.par.vpp.Out.AspectRatio=0:0
vpp.QueryIOSurf.par.vpp.Out.PicStruct=PROGRESSIVE
vpp.QueryIOSurf.par.vpp.Out.ChromaFormat=MONO
vpp.QueryIOSurf.par.Protected=0
vpp.QueryIOSurf.par.IOPattern=IN_SYSTEM_MEMORY|OUT_SYSTEM_MEMORY
vpp.QueryIOSurf.par.NumExtParam=0
vpp.QueryIOSurf.par.ExtParam=NULL
vpp.QueryIOSurf.request[0].Info.FourCC=0x0
vpp.QueryIOSurf.request[0].Info.Resolution=(0,0)
vpp.QueryIOSurf.request[0].Info.Crop=(0,0,0,0)
vpp.QueryIOSurf.request[0].Info.FrameRate=0/0
vpp.QueryIOSurf.request[0].Info.AspectRatio=0:0
vpp.QueryIOSurf.request[0].Info.PicStruct=UNKNOWN(0)
vpp.QueryIOSurf.request[0].Info.ChromaFormat=MONO
vpp.QueryIOSurf.request[0].Type=UNKNOWN(0)
vpp.QueryIOSurf.request[0].NumFrameMin=0
vpp.QueryIOSurf.request[0].NumFrameSuggested=0
vpp.QueryIOSurf.request[1].Info.FourCC=0x0
vpp.QueryIOSurf.request[1].Info.Resolution=(0,0)
vpp.QueryIOSurf.request[1].Info.Crop=(0,0,0,0)
vpp.QueryIOSurf.request[1].Info.FrameRate=0/0
vpp.QueryIOSurf.request[1].Info.AspectRatio=0:0
vpp.QueryIOSurf.request[1].Info.PicStruct=UNKNOWN(0)
vpp.QueryIOSurf.request[1].Info.ChromaFormat=MONO
vpp.QueryIOSurf.request[1].Type=UNKNOWN(0)
vpp.QueryIOSurf.request[1].NumFrameMin=0
vpp.QueryIOSurf.request[1].NumFrameSuggested=0
vpp.QueryIOSurf.status=MFX_ERR_INVALID_VIDEO_PARAM
i used the tracer  and got  these information
Petter_L_Intel
looks like the issue is that you're setting ChromaFormat to MONO. You should be setting this parameter to MFX_CHROMAFORMAT_YUV420 as illustrated in the Media SDK samples.
Petter
