Migrating to SYCL
One-stop forum for getting assistance migrating your existing code to SYCL
48 Discussions
CUDA to SYCL Migration guide and help
Developper
Hi
I am using Intel XEON Bronze CPU 3106 integrated with NVIDIA Quadro P 1000 .
We want to migrate CUDA code to SYCL to get performance details.
We have installed all prerequisites. please help to share some guides, resources to execute this process.
Vijay
NoorjahanSk_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
The Intel DPC++ Compatibility Tool (DPCT) is a tool that helps convert existing CUDA code into Data Parallel C++ (DPC++), which is based on the SYCL standard for heterogeneous computing. It's part of the Intel oneAPI Base Toolkit.
Please refer to below links for more details on usage of Intel Intel DPC++ Compatibility Tool
https://www.intel.com/content/www/us/en/developer/tools/oneapi/dpc-compatibility-tool.html#gs.1mohbe
https://www.intel.com/content/www/us/en/docs/dpcpp-compatibility-tool/developer-guide-reference/2024-0/migrate-a-project.html
https://www.intel.com/content/www/us/en/docs/dpcpp-compatibility-tool/get-started-guide/2024-0/overview.html
https://www.intel.com/content/www/us/en/developer/articles/technical/intel-dpcpp-compatibility-tool-best-practices.html
While DPCT automates much of the conversion process, it may still require some manual adjustments. The tool generates warnings with specific IDs (e.g., "DPCT10XX") to highlight areas where manual intervention is needed.
Please refer to below link for more details.
https://www.intel.com/content/www/us/en/docs/dpcpp-compatibility-tool/developer-guide-reference/2024-0/diagnostics-reference.html
Hope this helps to understand the migration process from CUDA to SYCL.
Thanks & Regards,
Noorjahan.
Developper
Hi
Thank for sharing this information.
We checked the working of the programs on GPU systems, only the CPU code execution is happening, but throwing an error related to its working on GPU. We tried a lot by resolving the errors, but the code is not working. Please find the screenshot of errors. Please help to resolve this.
NoorjahanSk_Intel
Based on the information in the screenshot you shared, it appears that you are attempting to run a dpc++ program on an NVIDIA GPU.
To target the NVIDIA GPU explicitly, you need to instruct the compiler to generate code for the specified device targets using the -fsycl-target flag.
Please refer to below link for more details on -fsycl-target on Intel devices.
https://www.intel.com/content/www/us/en/docs/dpcpp-cpp-compiler/developer-guide-reference/2024-0/fsycl-targets.html
We have tested this on our end with the NVIDIA plugin and did not encounter any issues
Steps we have followed:
>>icpx -fsycl -fsycl-targets=nvptx64-nvidia-cuda vector-add-buffers.cpp
>>/a.out
Running on device: Tesla P100-PCIE-12GB
Vector size: 10000
[0]: 0 + 0 = 0
[1]: 1 + 1 = 2
[2]: 2 + 2 = 4
[9999]: 9999 + 9999 = 19998
Vector add successfully completed on device.
We used icpx compiler with -fsycl flag, as dpcpp is deprecated and will be removed in future releases of oneAPI.
Please try above command to target NVIDIA gpu, if you still face any issues please provide us with sample reproducer and a complete error log.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Thanks & Regards,
Noorjahan.
Developper
Thank you. We will update for any queries.
NoorjahanSk_Intel
Could you please let us know whether your issue got resolved? If yes, please confirm whether we can close this thread from our end
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We are closing this thread assuming your issue has been resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Noorjahan.
