Migrating to SYCL
One-stop forum for getting assistance migrating your existing code to SYCL
48 Discussions
I encountered a problem when i try to use “ dpct::atomic_compare_exchange_strong” function
lisashi
I try to use this function “ dpct::atomic_compare_exchange_strong” .  and then I try to run pybind11 and python demo. Then I encountered this problem “Segmentation fault (core dumped)”. Do you have some suggestions to solve this problem.
This is dpct::atomic_compare_exchange_strong function
        uint64_t prev = dpct::atomic_compare_exchange_strong<
            unsigned long long, sycl::access::address_space::generic_space>(
            (unsigned long long *)&p.evHash[idx.get()], (unsigned long long)0,
            (unsigned long long)key);
This function is converted form https://github.com/NVlabs/nvdiffrast/blob/main/nvdiffrast/common/antialias.cu
Dpct convert this file successfully
Best
Lisa Shi
lisashi
i have found out this is a problem about cpu tensor and cuda tensor.  I should  make cpu tensor  in python program to call the dpct::atomic_compare_exchange_strong function
lisashi
ShwethaS_Intel
Thanks for reaching out to us. Glad to know that your issue is resolved. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Shwetha
