Migrating to SYCL
One-stop forum for getting assistance migrating your existing code to SYCL
48 Discussions
how to convert '__shared__ int' parameter in cuda to dpcpp
lisashi
hi
i try to convert a file from cuda to dpcpp. there is a '__shared__ int' parameter in this cuda kernel. i do not know how to use this parameter in dpcpp.
best
Lisa Shi
ManjulaC_Intel
For successful migration of CUDA to DPC++ follow the document below:
https://www.intel.com/content/www/us/en/developer/articles/technical/intel-dpcpp-compatibility-tool-best-practices.html
Shared local Memory in CUDA is migrated to accessors in DPC++. The access mode describes how we intend to use the memory associated with the accessor in the program. The accessor’s access modes are used by the runtime to create an execution order for the kernels and perform data movement.
Refer shared local memory access section in the below document:
https://www.intel.com/content/www/us/en/developer/articles/technical/cuda-sycl-migration-jacobi-iterative-method.html#gs.emcovr
Manjula
ManjulaC_Intel
Manjula
Dhimenvora
C++
struct complex
    float r;
    float i;
// __device__ := Invoke this function from device and execute it on device
__device__ complex operator*(complex a, complex b)
    return {a.r * b.r - a.i * b.i, a.r * b.i + a.i * b.r};
__device__ complex operator+(complex a, complex b)
   return {a.r + b.r, a.i + b.i};
__device__ float sqr_magnitude(complex c)
    return c.r * c.r + c.i * c.i;
ManjulaC_Intel
A gentle reminder to respond.
Manjula
ManjulaC_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel. Have a nice day!
Manjula
