16773 Discussões
一些错误 (Some Driver errors)
abcdefg
Principiante
2.336 Visualizações
我在下载驱动程序和支持助手时出现了问题 这是错误日志
(I had a problem downloading drivers and support assistants This is an error log)
15B4:1BF0][2021-08-15T11:51:41]i001: Burn v3.11.2.4516, Windows v6.1 (Build 7601: Service Pack 1), path: C:\windows\Temp\{FC3819EE-B2B1-49C0-88C9-CF674CE151E8}\.cr\Intel-Driver-and-Support-Assistant-Installer.exe [15B4:1BF0][2021-08-15T11:51:41]i000: Initializing numeric variable 'DCASelectedForInstall' to value '0' [15B4:1BF0][2021-08-15T11:51:41]i000: Initializing numeric variable 'DCAAskedUserForConsent' to value '0' [15B4:1BF0][2021-08-15T11:51:41]i000: Initializing numeric variable 'DCAConsentValue' to value '0' [15B4:1BF0][2021-08-15T11:51:41]i000: Initializing string variable 'IsLTSC' to value 'false' [15B4:1BF0][2021-08-15T11:51:41]i000: Initializing version variable 'VCRedist2015' to value '14.0.24215' [15B4:1BF0][2021-08-15T11:51:41]i009: Command Line: '"-burn.clean.room=C:\Users\Administrator\appdata\roaming\360se6\User Data\Default\open_direct\Intel-Driver-and-Support-Assistant-Installer.exe" -burn.filehandle.attached=180 -burn.filehandle.self=188' [15B4:1BF0][2021-08-15T11:51:41]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Administrator\appdata\roaming\360se6\User Data\Default\open_direct\Intel-Driver-and-Support-Assistant-Installer.exe' [15B4:1BF0][2021-08-15T11:51:41]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Administrator\appdata\roaming\360se6\User Data\Default\open_direct\' [15B4:1BF0][2021-08-15T11:51:42]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20210815115142.log' [15B4:1BF0][2021-08-15T11:51:42]i000: Setting string variable 'WixBundleName' to value 'Intel® Driver & Support Assistant' [15B4:1BF0][2021-08-15T11:51:42]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel' [15B4:1BF0][2021-08-15T11:51:44]i000: Loading managed bootstrapper application. [15B4:1BF0][2021-08-15T11:51:46]i000: Creating BA thread to run asynchronously. [15B4:0BA8][2021-08-15T11:51:47]i000: Launching custom Bootstrapper UI [15B4:1BF0][2021-08-15T11:51:50]i100: Detect begin, 5 packages [15B4:1BF0][2021-08-15T11:51:50]i000: Setting string variable 'NETFRAMEWORK45' to value '378389' [15B4:1BF0][2021-08-15T11:51:50]i000: Setting version variable 'VCRedist2015x86' to value '14.25.28508.0' [15B4:1BF0][2021-08-15T11:51:50]i000: Setting string variable 'WindowsBuild' to value '7601' [15B4:1BF0][2021-08-15T11:51:50]i052: Condition 'NETFRAMEWORK45 >= 394802' evaluates to false. [15B4:1BF0][2021-08-15T11:51:50]i052: Condition 'NETFRAMEWORK45 >= 461808' evaluates to false. [15B4:1BF0][2021-08-15T11:51:51]i052: Condition 'VCRedist2015x86 >= VCRedist2015' evaluates to true. [15B4:1BF0][2021-08-15T11:51:51]i101: Detected package: NetFx462Web, state: Absent, cached: None [15B4:1BF0][2021-08-15T11:51:51]i101: Detected package: NetFx472Web, state: Absent, cached: None [15B4:1BF0][2021-08-15T11:51:51]i101: Detected package: DriverSupportAssistantInstaller, state: Absent, cached: None [15B4:1BF0][2021-08-15T11:51:51]i101: Detected package: vc_redist.x86.exe, state: Present, cached: None [15B4:1BF0][2021-08-15T11:51:51]i101: Detected package: DCAInstaller, state: Absent, cached: None [15B4:1BF0][2021-08-15T11:51:58]i000: Setting string variable 'IsLTSC' to value 'false' [15B4:1BF0][2021-08-15T11:51:58]i199: Detect complete, result: 0x0 [15B4:0BA8][2021-08-15T11:52:13]i000: Setting numeric variable 'DCAAskedUserForConsent' to value 1 [15B4:0BA8][2021-08-15T11:52:13]i000: languageCode=zh_Hans [15B4:0BA8][2021-08-15T11:52:17]i000: Setting numeric variable 'DCASelectedForInstall' to value 1 [15B4:0BA8][2021-08-15T11:52:17]i000: Setting numeric variable 'DCAConsentValue' to value 1 [15B4:1BF0][2021-08-15T11:52:17]i200: Plan begin, 5 packages, action: Install [15B4:1BF0][2021-08-15T11:52:17]i052: Condition 'IsLTSC = "true" OR WindowsBuild < 14393' evaluates to true. [15B4:1BF0][2021-08-15T11:52:17]w321: Skipping dependency registration on package with no dependency providers: NetFx462Web [15B4:1BF0][2021-08-15T11:52:17]i000: Setting string variable 'NetFx462FullLog' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20210815115142_000_NetFx462Web.log' [15B4:1BF0][2021-08-15T11:52:17]i052: Condition 'IsLTSC = "false" AND WindowsBuild >= 14393' evaluates to false. [15B4:1BF0][2021-08-15T11:52:17]w321: Skipping dependency registration on package with no dependency providers: NetFx472Web [15B4:1BF0][2021-08-15T11:52:17]i000: Setting string variable 'WixBundleRollbackLog_DriverSupportAssistantInstaller' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20210815115142_001_DriverSupportAssistantInstaller_rollback.log' [15B4:1BF0][2021-08-15T11:52:17]i000: Setting string variable 'WixBundleLog_DriverSupportAssistantInstaller' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20210815115142_001_DriverSupportAssistantInstaller.log' [15B4:1BF0][2021-08-15T11:52:17]w321: Skipping dependency registration on package with no dependency providers: vc_redist.x86.exe [15B4:1BF0][2021-08-15T11:52:17]i052: Condition 'DCASelectedForInstall = 1' evaluates to true. [15B4:1BF0][2021-08-15T11:52:17]i000: Setting string variable 'WixBundleLog_DCAInstaller' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20210815115142_002_DCAInstaller.log' [15B4:1BF0][2021-08-15T11:52:17]i201: Planned package: NetFx462Web, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None [15B4:1BF0][2021-08-15T11:52:17]i201: Planned package: NetFx472Web, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None [15B4:1BF0][2021-08-15T11:52:17]i201: Planned package: DriverSupportAssistantInstaller, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register [15B4:1BF0][2021-08-15T11:52:17]i201: Planned package: vc_redist.x86.exe, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None [15B4:1BF0][2021-08-15T11:52:17]i201: Planned package: DCAInstaller, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: Yes, dependency: Register [15B4:1BF0][2021-08-15T11:52:17]i299: Plan complete, result: 0x0 [15B4:1BF0][2021-08-15T11:52:17]i300: Apply begin [15B4:1BF0][2021-08-15T11:52:17]i010: Launching elevated engine process. [15B4:1BF0][2021-08-15T11:52:17]i011: Launched elevated engine process. [15B4:1BF0][2021-08-15T11:52:17]i012: Connected to elevated engine. [1364:10FC][2021-08-15T11:52:17]i358: Pausing automatic updates. [1364:10FC][2021-08-15T11:52:18]i359: Paused automatic updates. [1364:10FC][2021-08-15T11:52:18]i360: Creating a system restore point. [1364:10FC][2021-08-15T11:52:18]w363: Could not create system restore point, error: 0x80070422. Continuing... [1364:10FC][2021-08-15T11:52:18]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{b09ce953-882c-4131-a693-2e1d73b1e50d}, options: 0x7, disable resume: No [1364:10FC][2021-08-15T11:52:19]i000: Caching bundle from: 'C:\windows\Temp\{6129469E-FF96-40BB-8E06-689858A4CD8A}\.be\Intel-Driver-and-Support-Assistant-Installer.exe' to: 'C:\ProgramData\Package Cache\{b09ce953-882c-4131-a693-2e1d73b1e50d}\Intel-Driver-and-Support-Assistant-Installer.exe' [1364:10FC][2021-08-15T11:52:19]i320: Registering bundle dependency provider: {b09ce953-882c-4131-a693-2e1d73b1e50d}, version: 21.5.33.3 [1364:10FC][2021-08-15T11:52:19]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{b09ce953-882c-4131-a693-2e1d73b1e50d}, resume: Active, restart initiated: No, disable resume: No [15B4:1368][2021-08-15T11:52:19]w343: Prompt for source of package: NetFx462Web, payload: NetFx462Web, path: C:\Users\Administrator\appdata\roaming\360se6\User Data\Default\open_direct\redist\NDP462-KB3151802-Web.exe [15B4:1368][2021-08-15T11:52:19]i338: Acquiring package: NetFx462Web, payload: NetFx462Web, download from: https://go.microsoft.com/fwlink/?LinkId=780596 [15B4:1368][2021-08-15T11:52:20]e000: Error 0x80072f0d: Failed to send request to URL: https://go.microsoft.com/fwlink/?LinkId=780596, trying to process HTTP status code anyway. [15B4:1368][2021-08-15T11:52:20]e000: Error 0x80072f0d: Unknown HTTP status code 0, returned from URL: https://go.microsoft.com/fwlink/?LinkId=780596 [15B4:1368][2021-08-15T11:52:20]e000: Error 0x80072f0d: Failed attempt to download URL: 'https://go.microsoft.com/fwlink/?LinkId=780596' to: 'C:\windows\Temp\{6129469E-FF96-40BB-8E06-689858A4CD8A}\NetFx462Web' [15B4:1368][2021-08-15T11:52:20]e000: Error 0x80072f0d: Failed to acquire payload from: 'https://go.microsoft.com/fwlink/?LinkId=780596' to working path: 'C:\windows\Temp\{6129469E-FF96-40BB-8E06-689858A4CD8A}\NetFx462Web' [15B4:1368][2021-08-15T11:52:20]e313: Failed to acquire payload: NetFx462Web to working path: C:\windows\Temp\{6129469E-FF96-40BB-8E06-689858A4CD8A}\NetFx462Web, error: 0x80072f0d. [15B4:1BF0][2021-08-15T11:52:20]e000: Error 0x80072f0d: Failed while caching, aborting execution. [1364:10FC][2021-08-15T11:52:20]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{b09ce953-882c-4131-a693-2e1d73b1e50d}, resume: None, restart: None, disable resume: No [1364:10FC][2021-08-15T11:52:20]i330: Removed bundle dependency provider: {b09ce953-882c-4131-a693-2e1d73b1e50d} [1364:10FC][2021-08-15T11:52:20]i352: Removing cached bundle: {b09ce953-882c-4131-a693-2e1d73b1e50d}, from path: C:\ProgramData\Package Cache\{b09ce953-882c-4131-a693-2e1d73b1e50d}\ [1364:10FC][2021-08-15T11:52:20]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{b09ce953-882c-4131-a693-2e1d73b1e50d}, resume: None, restart initiated: No, disable resume: No [15B4:1BF0][2021-08-15T11:52:20]i399: Apply complete, result: 0x80072f0d, restart: None, ba requested restart: No [15B4:0BA8][2021-08-15T11:52:20]e000: Failure from ApplyComplete: 0x80072F0D: None:
安装时出现未知问题。
(There was an unknown issue with the installation.
Some errors)
edited by Moderator
3 Respostas
AndrewG_Intel
Funcionário
2.314 Visualizações
Hello @abcdefg
请注意,我仅能以英语提供支持。我使用了一个 Web 翻译工具来翻译此响应,因此,可能有一些不准确的翻译。
In order to check this further, could you please provide the following information?
1- Please elaborate more on the specific issues and error messages that Intel® Driver & Support Assistant (Intel® DSA) is experiencing. If possible please provide some screenshots (if the screenshots are not in English, please kindly provide a description of them since we may not be able to translate screenshots attached to the thread).
2- What type of drivers are you trying to install/update using Intel® DSA? For instance, graphics drivers, wireless drivers? etc.
3- Did the software work fine before? If yes, what changes did occur at that moment? Was there any recent Windows* or driver update? Or was any hardware/software change? Please provide details.
4- Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
  • Download the Intel® SSU and save the application on your computer
  • Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click Next and click Save.
  • Once you have saved the file (.txt file), please attach the file to your reply.
To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Andrew G.
AndrewG_Intel
Funcionário
2.264 Visualizações
Hello abcdefg
We are checking this thread and we would like to know if you need further assistance.
Also, we would like to inform you that our Intel® DSA developers reviewed the error log that you posted and it could be that the error is being caused by an issue with the network. This could be a firewall setting or some other network configuration. But when the install runs it needs to hit some Microsoft* URLs. This is failing and hence the install failure.
Perhaps you need to allow the correct ports to be accessed? The Intel® DSA accesses localhost on ports 28385-28389. It also connects to www.intel.com, downloadcenter.intel.com, and downloadmirror.intel.com, all on port 443 (HTTPS). For more details please review this article: Things to Know Before I Start to Use the Intel® Driver & Support Assistant (Intel® DSA).
Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
AndrewG_Intel
Funcionário
2.243 Visualizações
Hello abcdefg
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
Responder
