0x129
Alecio
Tenho no PC o processador I9 1900KF, fiz a atualização da bios (0x129) a tensão chega acima de 1.5V, antes de atualizar estava operando abaixo de 1.5V
VonM_Intel
Hi, Alecio.
Informamos que só posso apoiá-lo em inglês. Usei uma ferramenta de tradução da web para traduzir essa resposta, portanto, pode haver alguma tradução imprecisa.
Thank you for posting in our Community and for sharing the details. I understand that the voltage has increased above 1.5V after the BIOS update, which could be concerning. Higher voltages can potentially affect both the stability and longevity of your processor.
To proceed with investigating the issue, I would like to confirm the following:
  • Did you overclock the processor? Please note that if the system was overclocked, including voltage/frequency beyond the processor-supported specifications, your processor voids the warranty.
  • Is the voltage consistently staying above 1.5V, or does it fluctuate? Have you observed any changes in voltage under load versus idle?
  • Have you monitored the temperatures of your CPU since the update? Are there any noticeable temperature spikes that correlate with the higher voltage?
  • Did you notice any other significant changes in the BIOS settings after updating to version 0x129? For example, any changes in fan profiles, power limits, or other CPU settings?
  • Since the voltage increased, have you experienced any system instability, crashes, or unexpected behavior (like thermal throttling or crashes)?
Your responses will help in resolving the issue more effectively.
Have a nice day!
Von M.
VonM_Intel
Hi, Alecio.
Were you able to check the previous post? Kindly let us know if you still need assistance.
Von M.
DhannielM_Intel
Hi, Alecio.
I have not heard back from you so I will now close this inquiry. If you require a further assistance or other inquiry, please submit another thread as this one will no longer be monitored.
Dhanniel M.
