12700K settings
chugzillafx
ok so all the hype-hoopla has been about the 13th-14th gen and instability issues etc.
and i found this graph-see image.
why isn't there one for the 12th gen K series so we know proper settings?
ACarmona_Intel
Hello Chugzillafx,
Thank you so much for the quick response.
In regards to your concern, we highly recommend that you use the BIOS default settings, as they assure that all of the features installed will be functioning according to their designed specifications.
Furthermore, altering the clock frequency or voltage may void any product warranties and reduce the stability, security, performance, and life of the processor and other components.
For more information regarding overclocking, you may check out the following links:
To summarize, we suggest that you use your BIOS default settings; however, you are free to overclock your processor if you wish to maximize the performance of your CPU.
If you have any questions or need further explanation, please let me know.
Carmona A.
ACarmona_Intel
Hello Chugzillafx,
We wanted to inform you that Intel Default Settings is our way to address or work around the reported issue relating to 13th and 14th generations as we continue to further investigate the issue and find the root cause.
Which means that other processors that have not been affected or do not experience the issue should follow the default BIOS settings of their system.
If you have any questions, please let me know.
Carmona A.
chugzillafx
well i have a 12700K i just got and new Asus Tuf plus wifi6 mb.
I'm asking because i wasn't sure if i should use the intel default profile or just use whatever settings i want.
i didn't want to ruin the 12700K is all not knowing what settings for it are best.
would it be best if i leave the BIOS default then use the XTU preset called speed optimizer?
ACarmona_Intel
Hello Chugzillafx,
Carmona A.
chugzillafx
ty i have been using XTU until recently i discovered the MB BIOS has an OC tuning feature im using.
ACarmona_Intel
Hello Chugzillafx,
Thank you so much for the response.
We understand, It seems that you no longer have other enquiries for us. In regards to this, we will now proceed with closing this case. For additional information, please submit a new question, as this thread will no longer be monitored.
Thank you so much for your time, and have a great day ahead!
Carmona A.
