16797 Discussions
14700k Freeze randomly
AshkanSp
Hello, I have a problem regarding freezing while playing or afk. After some time the computer just freezes and nothing happens. I have to turn it off and on again. I have updated all drivers, BIOS to the latest version.
MB - ASUS Z790 A prime
Processor - Intel i7-14700K
RAM - VENGEANCE 32gb 6000mhz
GPU - zotac GeForce RTX 4070ti
SUPER GAMING OC 12G
PSU- Cooler master 1200 atx
AlHill
Make sure your memory is in spec:
Up to DDR5 5600 MT/s
Up to DDR4 3200 MT/s
[W10 is this generation's XP]
AshkanSp
right now im using 4800 MT/s
XMP disabled
AlHill
DDR5 or DDR4?
Still freezing or not?
AshkanSp
DDR5 , yes randomly some times
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
JeanetteC_Intel
Hello AlHill,
Thank you for the helpful guidance! I will handle it from here.
Sincerely,
JeanetteC.
AshkanSp
Thank you for your help. file uploaded here
JeanetteC_Intel
Hello AshkanSp,
I would like to know more about your system details to fully understand where the issue truly lies. Please provide the missing key information here:
1) Is this an out-of-the-box issue, or has the system worked before this issue started?
2) What were the recent changes made prior to the issue? (Hardware add-ons, software/application installations, OS and drivers updates, settings from BIOS changed, etc.)
3) Please share your Windows event logs from the Event Viewer.
JeanetteC.
AshkanSp
hey , i just increased AC LL and DC LL and its fixed but cost alot performance drop , right now im waiting for new microcode and bios update
JeanetteC_Intel
Hello AshkanSp,
Thanks for letting me know about this update. I see that while the issue is resolved, performance is still a concern and requires attention. It's a smart decision to wait for the upcoming microcode, as Intel advises updating the BIOS to the latest version with microcode 0x12F or newer. I recommend contacting your motherboard manufacturer's support team for additional help.
JeanetteC.
